Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#11 | |
![]() Last edited by techmate; 19th November 2018 at 09:50 AM. |
#12 |
will be nice if i could pack all togheter in one box which is going to be Psu box and from there cables that will feed dac and amp
#13 | |
Logically seen, keeping the linear regulators near the consumers (the class A headphone amp and the TP50) ensures better regulation for the power inputs. The two linear regulators may be arranged in one box. Then, the SMPS power adapters at a certain distance because they may radiate noise. That is how I would do it. |
#14 |
I checked my DACMagic (Cambridge Audio) and I also feed it 12Vac to keep it happy. It is absolutely correct. The reason for the AC supply is probably that it is used to generate symmetrical supply voltages through single rectification. Then charge pumps are avoided. |
#15 | |
Regards, |
#16 |
#17 | |
Thanks for the reply. I guess my comment was more directed at the fact that I just solely have the12v toroid and no other components.....no regulation or whatever. It is a 200VA job so shouldn't struggle to fees the DAC! One question regarding the OPs situation....if we are to implement linear regulation to a DC supply....I can't find any ready made boards that can do 4 , 5, 6 Amps etc as may be required from a power amplifier. Are there some out there I haven't yet landed on? Last edited by jimk04; 20th November 2018 at 05:43 PM. |
#18 | |
With such post regulators the ripple and step response will improve compared to your present SMPS adapters. I chose for commonly available LM317 and LM338 because they perform well and are easy to get. You can find ultra low noise regulators that will need to be put in parallel to provide sufficient current. My unqualified impression, for which I will soon be battered, is that you will not notice the difference for the actual use. Last edited by FauxFrench; 20th November 2018 at 08:17 PM. |
#19 | |
I agree with you, linear regulator kits/boards for 3-8Amp are difficult to find. Most power amplifiers run from unregulated supply voltages. A 3-8A linear regulator is rather simple so design with an LM317 or LM337 and a 15A buffer transistor controlled by the regulator. I have made one doing +/-16V-42V, 6A and work on a +/-2-15V/3A for low power experimental use. Using a suitable IC regulator chip makes design of a linear regulator rather simple. Only if you really know your circuits, discrete power supply constructions are worth considering. |
#20 | |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Super Squirrel Monkey - First from-scratch tube amp build, first guitar amp build | ericj | Instruments and Amps | 33 | 22nd June 2020 08:26 AM |
First build linear PSU help - load balancing outputs. | atca | Power Supplies | 14 | 25th September 2018 02:04 PM |
Help a novice steadily build a linear 12V power supply? | SGK | Power Supplies | 117 | 27th May 2014 08:38 AM |
SMPS vs LINEAR PS: Let's build up a serious technical review-list | Centvrion | Power Supplies | 18 | 7th March 2011 05:09 AM |
build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 08:54 AM |
New To Site? | Need Help? |
