Our old sockets are the best looking though
True!
I don’t know what “PE” stands for.
If the sockets only have live and neutral I would be inclined to add an isolation transformer.
Note that using pipework as a ground can be very dangerous if it isn’t actually grounded. A connection between live and pipes could give someone else in the building a shock. I believe this avoided if an isolation transformer is used.
I don't understand where the ground would attach on the fo-felix, even if I had it?
Me either.
There does seen to be some opinions floating around that an isolation power supply does have some 'audible' benefits. But, as seen in this thread careful design and implementation is necessary to prevent any kind of shock hazard.
Here's some good information on grounded versus ungrounded neutrals in the context of isolation.
Topaz Low-Capacitance Isolation Transformers - for Affordably Clean Power | Headphone Reviews and Discussion - Head-Fi.org
Dan
Dan
As far as a DIY Isolation supply goes. The following has peaked my interest.
One of these combined with a FO-Felix.
Isolation Transformer 150VA
Dan
Dan
Based on Fo-felix EMI filters
Setup is:
- Surge filter with 4X S20K275 MOV's
- DC-blocker with 2x 16V/100.000µf Epcos in anti-parallel
- - DC-blocker can be bypassed with switch
-- Higher white LED on front will be off when bypassed
- 2x Fo-Felix filter with Bourns CMC8120
-- 2X Fo-Felix with Comoco P3717 -3A
-- 2X Fo-Felix with Comoco Q4007 -5A
-- 2X Fo-Felix with Comoco Q4018 -10A
-Neutrik 32A plug for mains inlet
- 2 white indication LED's on front (Power ON + DC-blocker activated)
Enclosure is made out of black HPL plate.
Top will be made out of 6mm glass.
Setup is:
DIY porn
Nice - very nice device ! ! ! KUDOS !
Setup is:
How did you get the Ben Janssen PCBs? I see a group buy for the Fo-Felix but not for the other boards.
Ah OK, I assumed that the person running the group buy was the designer. I see now that your pcb is not the same as the group buy. Do you have any of these boards available? Would make my power conditioner build a lot easier if i had a surge protector and 6 filter boards!
- Power Supplies
- Power conditioner build
