Hi
I will be experimenting with some Amplifier modules that require 12v DC. I would like to use a battery instead of a wall AC Adapter,
and looking for a recommendation on one, that is also simple to recharge. By "simple to recharge" I mean in terms of the circuit needed for the charging part..
Can anyone recommend something nice?
Thank you
Thank you
Is this a car amplifier, and how much current does it need?
It's not defined as a car amplifier, it's those simple Class AB amplifier modules that you can buy in ebay, such as TDA7297, or TDA7377. What's special about these 2, is that unlike many other Class AB Amplifiers which require a Dual Rail power supply, here it's simply 12v, in the regular configuration.. (12v, Gnd)Is this a car amplifier, and how much current does it need?
Thank you lineup.A small 12 Volt lead battery is recomended. Such batteries is for motorbikes and similar.
I am curious, why Lead batteries are recommended? (are there 12v batteries that are Ni-MH, Li-Ion, and other materials, like we use in smaller voltages?)
Oh, so Lead is due to simplicity - great.Most modern battery technology needs a complicated circuit to charge and keep the battery safe. You asked for something simple, so you have to use an older battery technology.
You did not mention Ni-MH, so this means Ni-MH is (relatively) complicated too, in terms of charging?NiCd were fairly easy to handle, but they are now banned in many countries.
This looks like it might be useful:
Dayton Audio LBB-3 3 x 18650 Lithium Battery Charger Board / Module 12V with Charge Protection
Thank you Good E Nuff,
but this looks like a Step-Up converter. 18650 batteries are 3.7v, 3 of them will be 11.1 (or less, when not fully charged), so it's mostlikely that this module has a Switching Mode Step-Up converter. A 12v battery on the other hand (real 12v, not step-up), has the advantage over a step-up, which is the fact that it will give a perfect DC..
You could also try 12V power tool packs. Two batteries and the correct charger are often sold together at a decent price. This gives continuous use. They also have a very large peak current capability.
I'd go with VRLA types as well (lead acid gel batteries) but please do include a suitable fuse in the positive lead because the short circuit current delivery is huge (100A and above).
I've just today replaced a small 12v 2.1Ah Yuasa battery in an alarm panel. I fitted it originally in 2003 and it still powered the panel OK in the absence of mains although when loaded even to 0.5A current draw the terminal voltage heads south to around 10 volts. I've a 6Ah one I use for various electronics stuff (and running a laptop ) and that must ten years old now but still retains its capacity. They are surprisingly cheap as well, even for the top name brand.
I see, in that case Lead Acid is the chosen type..NiMH is not too bad, but not quite as simple as NiCd or lead-acid.
You're talking about the batteries that come with Drills/Electric Screwdrivers and such tools? What a fantastic idea.You could also try 12V power tool packs. Two batteries and the correct charger are often sold together at a decent price. This gives continuous use. They also have a very large peak current capability.
I didn't know their battery is Lead Acid.. (are they always Lead Acid?) It's a great way to buy both the battery and the charger..
What is the difference etween VRLA and Lead Acid Gel?I'd go with VRLA types as well (lead acid gel batteries)
Oh..but please do include a suitable fuse in the positive lead because the short circuit current delivery is huge (100A and above).
Thanks for the tip.. I will include a fuse.
Great.. Advantages of Lead Acid, What we would not get from Ni-MH or Li-Ion.. Nice to hear this..I've just today replaced a small 12v 2.1Ah Yuasa battery in an alarm panel. I fitted it originally in 2003 and it still powered the panel OK in the absence of mains although when loaded even to 0.5A current draw the terminal voltage heads south to around 10 volts. I've a 6Ah one I use for various electronics stuff (and running a laptop ) and that must ten years old now but still retains its capacity. They are surprisingly cheap as well, even for the top name brand.
and such tools? I didn't know their battery is Lead Acid.
They aren't.
But they work and come packaged as a complete system, an example of reuse of technology that has the benefit of another application that has a large economy of scale.They aren't.
Sorry, I meant single battery cells, I don't know of any battery chemistry that's 12v by itself. I'm not sure there's an electrochemical reaction that goes that high on the Nernst equation. Eg each li-ion is between 3.6 and 4.2, so you put 3 cells in series for a 12v battery. Pretty sure lead-sulfuric cell is about 2.2 V. So a standard 12 v lead-acid battery is 6 cells in series.
Sorry I should have said series parallel. The power tools would not work with step up switchers.
- Power Supplies
- Looking for a Recommendation on a 12v Battery that is Simple to Recharge
