OK to have different values on caps in a CRC PSU?
Old 4th October 2018, 09:28 PM   #1
Hubba is offline Hubba  Sweden
Default OK to have different values on caps in a CRC PSU?
So, i'm about to start on my second F5 amp. I've got two huge 33000 uF and a couple of 15000 uF caps which I would like to use, so my simple Q is:
Standard F5 psu (CRC) states min 30000 uF per rail, and I would like to mix 33000 and 15000 uF caps and I just would like to get it confirmed that it will not be a problem. (I reasoning the more uF per rail the better, and I got the parts..)
The total uF per rail will of course be the same (i.e 1x33000 + 3x15000)
Thanks,
Fredrik
Old 4th October 2018, 09:58 PM   #2
rayma is offline rayma  United States
That will work in this case, but for high ripple current applications
the capacitors should all be the same so they will heat equally.
Old 5th October 2018, 08:18 AM   #3
Vovk Z is offline Vovk Z  Ukraine
Originally Posted by rayma View Post
That will work in this case, but for high ripple current applications the capacitors should all be the same so they will heat equally.
"F5" - I guess it is Nelson Pass F5 First Watt amp: Output power stereo 8 ohms 25 watts @ 1% THD, 1KHz. Here is a link to pdf.
So, it doesn't need very high ripple current. I think there isn't problem with current sharing.
Old 5th October 2018, 08:22 AM   #4
I think it may be a little better to start CRC with lower value (15000 uF) and end with larger value (33000 uF).
I put a picture to help people.
OK to have different values on caps in a CRC PSU?-f5-fw-ps-png
OK to have different values on caps in a CRC PSU?Hide this!Advertise here!
What values are these caps? -- replacing Velodyne SPL II amp caps Jimmy154 Class D 6 9th February 2017 01:50 PM
what are best decoupling caps and values for pcm63 samoloko Digital Source 2 28th December 2009 12:21 PM
Bypass caps values advice AndrewGM Solid State 2 27th May 2009 10:48 PM
Parallel Caps for Large Values.. jethdub Parts 7 25th January 2008 12:08 AM
caps and values theChris Parts 0 23rd December 2002 07:32 AM
