Develop ultra capacitor power supply and LiFePO4 battery power supply
Old 21st November 2019, 01:48 AM   #771
hibo4 is offline hibo4  New Zealand
I'm confused by Ian's post 764 where he says not to series 3.3v batteries with caps paralleled. From one of G Stew's posts, the battery board relays parallel all batteries when in charge mode so paralleled caps would be charged at 3.3v. When in power mode, the batteries will power as each rail has been arranged at the output connections whether paralleled, in series or a combination of each. How am I figuring this wrong?
Martin.
Old 22nd November 2019, 11:52 PM   #772
Greg Stewart is offline Greg Stewart  United States
Actually I suspect it charges all cells via individual charging circuits, so that if a higher-current draw from a connected device has drained the connected cell or cells deeper than others connected to other devices, charging the deeper-discharged cells to the target end-charge voltage won't overcharge the other cells on the board.
Ian, can you clarify?
Greg in Mississippi
Everything matters!
Old 23rd November 2019, 08:50 PM   #773
Supersurfer is offline Supersurfer  Netherlands
Originally Posted by randytsuch View Post
I was curious and checked the avx scp datasheet.
I see an dc esr of 39 milliohm for the 11F device (lowest they have)
PN SCPA32A116PNA
20A part is worse, double that number.
You are right, I saw the general spec stating: Low ESR: <1mΩ. Thatís probably only on big caps.
It seems the only way to get low esr is big caps.
Old 23rd November 2019, 09:01 PM   #774
clsidxxl is offline clsidxxl  France
clsidxxl's Avatar
Originally Posted by iancanada View Post
If I had chance to update my LifePO4 power supply design down the road, I will make it compatible with a ultra capacitor board to make things easier to upgrade to a hybrid power supply.
Ian
Ian an ultra capacitor extending board which is added to the LifePO4 power supply,is a great idea.
Old 23rd November 2019, 09:59 PM   #775
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Develop ultra capacitor power supply and LiFePO4 battery power supply
Why not do a lifepo board for transformer output stage only, smaller board, fewer batteries, offsets cost of supercap board and saves some space?
Old 24th November 2019, 10:52 PM   #776
TirNaOg is offline TirNaOg
Ultra capacitor/LifePO4 hybrid power supply could be so far the best 3.3V rail in the world. ....
It will give you a big surprise.
Ian
Tried the ultra cap upgrade this weekend and it did give me a big surprise.
More natural easeful sound and extended dynamics, feel much closer to the music.
Iím powering an SD card player and I2s to HDMI module both on 3.3v. Superb result. Best my system has sounded. Thanks very much Ian!
Old 25th November 2019, 11:27 AM   #777
rowli is offline rowli  Sweden
Do you use some on/off switch or relay after the ultra cap, so it does not discharge if you turn of you stereo for a few days. Any recommendations?
Old 25th November 2019, 05:34 PM   #778
The capacitor is always connected with the battery, as long as you do not drain the battery it wil stay charged when in isolated (off) state; the battery module is isolated with a relais.
This makes me wonder how much leakage the capacitors will have and if they are able to drain the lifepo4 battery when the battery module is switched off for a longer period of time (like for instance when you are away on summer holiday for 3 weeks).
Old 25th November 2019, 06:30 PM   #779
nounouchet is offline nounouchet  France
If an ultracapacitor is used, why not leave the 3 ohms resistance between it and the batteries?
Indeed, we keep the benefit of supplying the electronic circuit with the ultracapacitor, we secure the assembly and we keep the benefit of batteries PSU.
The voltage drop in the resistance is negligible for small consumption of digital circuits.
nounouchet
Old 25th November 2019, 07:05 PM   #780
randytsuch is offline randytsuch
nounouchet
I think a big reason why ultracaps and lifepo4 batteries do well is their very low output impedance. Adding 3 ohms negates the low output.
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Develop ultra capacitor power supply and LiFePO4 battery power supplyHide this!Advertise here!
FS: ultra low noise power supply with 6 LT3045 Shutdown98 Swap Meet 1 13th June 2018 08:28 PM
Ultra Low Noise Lab Power Supply branadic Equipment & Tools 0 4th September 2017 07:02 PM
Battery power/power supply from wall charger for BT speaker satx Chip Amps 72 3rd July 2015 11:28 PM
Scavenging ultra low noise power supply jackinnj Power Supplies 3 7th September 2008 05:32 PM
Copyright ©1999-2019 diyAudio
