Develop ultra capacitor power supply and LiFePO4 battery power supply
Old 6th December 2018, 02:10 AM   #311
ofswitched is offline ofswitched  Taiwan
Originally Posted by iancanada View Post
For McDual XO you can do it so to reduce power supply internal resistance even more. But for McFifo, you don't need to.
Ian
My mistake, I think of McFIFO as McDual XO.
If I am not mistaken, McFIFO should not need to be powered by batteries, use a general linear power supply?
Old 6th December 2018, 02:37 AM   #312
iancanada is offline iancanada  Canada
iancanada's Avatar
Yes, you are right. It's not really necessary for anything before isolator to use battery power.
Ian
Old 6th December 2018, 06:43 AM   #313
acg is offline acg  Australia
Ian,
How is the power supply turned on and off? Is it the tactile switch/encoder next to the led screen? Can a normal SPST remote switch also be used?
Anthony
Old 6th December 2018, 01:05 PM   #314
iancanada's Avatar
@acg
There are 3 ways to turn on/off the LifePO4 power supply.
1. Press and hold the knob encoder on the OLED panel.
2. Form a external control button which is connected to the on/off PIN on the PCB.
3. By the on/off signal (3,3V-12V DC level, input is isolated) from external master power supply or controller through the bridge cable socket. This feature makes it possible that more LifePO4 power supplies can be bridged together to have more voltage rails or higher voltage.
Ian
Old 6th December 2018, 06:10 PM   #315
Tesla Audio is offline Tesla Audio  Croatia
Tesla Audio's Avatar
Hi Ian
Is any LiFePO4PowerSupply_1 board available?
Old 7th December 2018, 12:56 AM   #316
iancanada's Avatar
@Tesla Audio
They will be available in a couple of weeks.
Thank you for interest.
Ian
Old 7th December 2018, 01:00 AM   #317
@acg
Ian
Why not buy an RF module for an option? The RF module in this photo is only for $2. Taobao can bought a remote control module that supports Android phones.
Old 7th December 2018, 06:39 AM   #318
Ian do you know approximately price for pcb and cost for all electronic elements?
Old 7th December 2018, 09:50 AM   #319
koldby is offline koldby  Denmark
koldby's Avatar
Hi.
I would like to use LifePO4 battery supply for my TDA1541A DAC but the data sheet for TDA1541A says Max +/- 5,5V and - 16V with absolute max @ +/- 7V and -17V. LiFePO4 can supply +/- 6,6V and -16,5 V.
A little too close to the absolute max.
Has anyone tried this?
Would it degrade the direct battery power quality if i place a silicon diode in series with each of the three supply lines? That would lower the voltages to +/- 6V and -15,9V...
What is Home Theatre without good sound?
Old 7th December 2018, 10:15 AM   #320
Blitz is offline Blitz  Germany
Ian LiFePO4 Power supply principle block diagram
Voltage rails:
1, Low noise linear regulated 5V 2A: for digital sections (before isolator is suggested);
2, Pure LifePO4 battery power 3.3V: for clock board;
3, Pure LifePO4 battery power 3.3V: for DAC;
4, Pure LifePO4 battery power 3.3V or 6.6V or 9.9V or 13.2V: for I/V stages or analog sections;
5, Pure LifePO4 battery power 3.3V or 6.6V or 9.9V or 13.2V: for I/V stages or analog sections;
All voltage rails are independent from each other.
All battery powered rails are isolated from DC input
Multiple LifePO4 boards can be bridged together for more power rails.
Normal laptop power adapter would be good option as DC input.
LifePO4PowerSupplyBlockDiagram
by Ian, on Flickr
Ian
Let me see if I get it right for my battery order:
- Each board has four battery rails.
- So if each of them would have 3.3V, this means four batteries to buy...right ? Or did you configured the board so that you could use all the slots for batteries in any case, resulting in a higher capacity by paralleling batteries ?
If I want 26V: Possible with two battery rails in series (...for the CCS of my LTP-Tube stage) ?
Best Regards
Frank
Develop ultra capacitor power supply and LiFePO4 battery power supplyHide this!Advertise here!
FS: ultra low noise power supply with 6 LT3045 Shutdown98 Swap Meet 1 13th June 2018 08:28 PM
Ultra Low Noise Lab Power Supply branadic Equipment & Tools 0 4th September 2017 07:02 PM
Battery power/power supply from wall charger for BT speaker satx Chip Amps 72 3rd July 2015 11:28 PM
Scavenging ultra low noise power supply jackinnj Power Supplies 3 7th September 2008 05:32 PM
