Develop ultra capacitor power supply and LiFePO4 battery power supply
Old 7th September 2018, 08:57 PM   #11
esl 63 is offline esl 63
Some 25V Electrolytics and then polyprop close to the consumer circuit, this could work... I want to see measurements as well, maybe a shunt regulator could do the final dBs..
Old 7th September 2018, 09:01 PM   #12
GOR3 is offline GOR3  United States
Rayma,
I've had the same experience as Ian over about the same period of time. I use two cells, one to recharge while the other is in place, so each has about half the use (until one of them, harboring an undisclosed suicide wish, became involved in a brief but spectacular welding incident).
George
Old 7th September 2018, 09:08 PM   #13
wcwc is offline wcwc  United States
Would each power supply only be able to supply power to one location? Do we treat it like a regulator?
Old 7th September 2018, 10:03 PM   #14
iancanada is offline iancanada  Canada
iancanada's Avatar
@wcwc
Try one rail for one location as possible as you can. However based on my real experience, one rail for multiple location would still be OK due to the very low internal impedance. Just trust your ears.
I do not suggest using and LDO or regulator after LifePO4 or ultra capacitor power supplies, that could degrade the power supply quality.
A lot of people use the small battery manage board for my FIFO project. It's OK, doesn't change the good sound quality, but just feels like a prototype. I'm gonna design a completed all in one solution this time, more closed to finished .
Ian
Old 7th September 2018, 10:18 PM   #15
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Hi Ian. How do you intend to do the switching between the ultracap banks? Relays?
Great projects as always, cannot wait
Old 7th September 2018, 10:19 PM   #16
mcluxun is offline mcluxun  United States
Subscribed.
I'm thrilled to use them in my system.
Old 7th September 2018, 10:29 PM   #17
acg is offline acg  Australia
Subscribed. Very interested.
Old 7th September 2018, 10:51 PM   #18
iancanada's Avatar
@analog_sa
To switch between ultra capacitor banks, relays would have better isolation performance. However, they are a bit noisy, even to switch them every 5 to 10 minutes.
MOSFETs don't have this kind of problem, but they have small leak capacitance around tens of pF. This number could be still reduced by half if to switch both ground and power rail at same time.
MOSFET solution could also be complicated but more flexible.
It's really hard to decide
Regrads,
Ian
Old 8th September 2018, 04:03 AM   #19
iancanada's Avatar
I have enough LifePO4 cells to do the test
LifePO4BatteryPack
by Ian, on Flickr
Ian
Old 8th September 2018, 09:52 AM   #20
clsidxxl is offline clsidxxl  France
clsidxxl's Avatar
Hi Ian,The most famous subject of the year
Develop ultra capacitor power supply and LiFePO4 battery power supplyHide this!Advertise here!
FS: ultra low noise power supply with 6 LT3045 Shutdown98 Swap Meet 1 13th June 2018 08:28 PM
Ultra Low Noise Lab Power Supply branadic Equipment & Tools 0 4th September 2017 07:02 PM
Battery power/power supply from wall charger for BT speaker satx Chip Amps 72 3rd July 2015 11:28 PM
Scavenging ultra low noise power supply jackinnj Power Supplies 3 7th September 2008 05:32 PM
