Develop ultra capacitor power supply and LiFePO4 battery power supply
Thread Tools
Old 21st July 2021, 11:47 AM   #1581
iancanada is offline iancanada  Canada
iancanada's Avatar
@hires,
It should be in balanced if you don't see any red LEDs.
Or, just measure the voltage over the two ultra capacitors.
Ian
Old 21st July 2021, 12:35 PM   #1582
hires is offline hires
Ian,
On the UcHybrid board there are only two LEDs:
D2 Power indicator and D1 condition indicator.
There is no overvoltage indicator.
In this situation it's impossible to understand that there is an ongoing imbalance.
Old 21st July 2021, 06:14 PM   #1583
iancanada's Avatar
When UcHybrid is fully charged, the voltage on each ultra capacitor will be only 1.65V, that's far from the 2.7V rated voltage. So, UcHybrid was designed to use passive balancer. There will be enough headroom and time to reach the balance point if the voltages are slightly different over the two UCs.
Ian
Old 22nd July 2021, 06:53 AM   #1584
Hi Ian,
thank you!
  Reply to this post
Develop ultra capacitor power supply and LiFePO4 battery power supplyHide this!Advertise here!
Thread Tools
FS: ultra low noise power supply with 6 LT3045 Shutdown98 Swap Meet 1 13th June 2018 07:28 PM
Ultra Low Noise Lab Power Supply branadic Equipment & Tools 0 4th September 2017 06:02 PM
Battery power/power supply from wall charger for BT speaker satx Chip Amps 72 3rd July 2015 10:28 PM
Scavenging ultra low noise power supply jackinnj Power Supplies 3 7th September 2008 04:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
