Develop ultra capacitor power supply and LiFePO4 battery power supply
Old 12th October 2018, 04:05 AM   #141
ofswitched is offline ofswitched  Taiwan
With audio amplifiers, the demand for energy storage greatly increases because of the non-constant power supply drain (by the amplifier responding to the musical signal). In addition to the energy storage needed to decouple AC from the DC output of the power supply, we need additional energy storage to properly decouple the Audio Amplifier from the DC output of the power supply. This is true even with the most constant “music” we could imagine—a single tone. If we listened to a single 20 Hz tone (considered the lowest frequency humans can hear), the energy surge peaks would occur 20 times per second. This would impose the requirement of energy storage for the 50 ms duration.
To get the real benefit of music power averaging, the energy storage time must be greatly extended because music power requirements are more-or-less “random” in nature and do not follow a specific form. Generally, a longer time constant energy storage mechanism would result in “better” averaging, resulting in lower average power level required of the power supply.
A typical power supply for an audio amplifier:
Is rated for peak audio power because it must supply sufficient power during peak demand (for example a drum beat).
Uses capacitors for energy storage. The energy storage medium must be part of the power supply because the Energy Storage Medium must filter (equalize, decouple) non-constant AC power source, being 50 or 60 Hz. Therefore, the energy must be stored to provide constant (DC) power even though the source provides AC, which is non-constant.
In addition to above: the Energy Storage Medium must filter (equalize, decouple) non-constant power load due to the unpredictable varying nature of a musical waveform.
Old 12th October 2018, 04:54 AM   #142
punci is offline punci
Default Hi there!!
4x3 low noise ldo 4 parallel,3 serial like 12v-5v- 3.3v with power regenerator easy can beat any ultracaps or batteries.
Old 12th October 2018, 08:26 AM   #143
TioFrancotirador is offline TioFrancotirador  Poland
@iancanda
Fantastic job Ian! Still waiting for ultracap PSU, though
Old 12th October 2018, 10:11 AM   #144
Morde is offline Morde  Finland
Great work, can't wait for GB!
My finished headphone amp projects: 1, 2, 3, 4, 5, 6, 7
Old 12th October 2018, 10:55 AM   #145
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Develop ultra capacitor power supply and LiFePO4 battery power supply
They really can't.
Paradise Pre-reg PSU PCBs
Old 12th October 2018, 01:48 PM   #146
who are you man? account created today and just one post ... what is your intent here?
Old 12th October 2018, 02:20 PM   #147
iancanada is offline iancanada  Canada
iancanada's Avatar
According to your knowledge, can you explain what's the difference between LDOs and passive power supplies such as LifePO4 batteries and ultra capacitors?
Thanks,
Ian
Old 12th October 2018, 06:09 PM   #148
clsidxxl is offline clsidxxl  France
clsidxxl's Avatar
Very nice Ian congratulation
Old 12th October 2018, 06:48 PM   #149
RolandPSP is offline RolandPSP  Romania
PM-ed
Old 15th October 2018, 01:28 AM   #150
Thanks,
Ian
Sorry about that,but this is my personal experience.Thats why I reg here.
(also my English not so perfect...)
uptone Lps1.2(I sold it,not independent psu) also similar with 4pcs lt3045. other Nesscap 10 farad caps psu sound much better than powerstor 100f. single lt 1963 ldo sound crap,but 4x parallel(no need ballast resistor),and 3 step down with power regenerator very good!!!!Without power regenerator in my home nesscap psu win.I make alredy 8 pcs powerstor psu with relay,4 nesscap psu,around 300 pcs ultracaps total. Vs studer 900 psu, sigma 11 , around 50 lt3045, 60 pcs Lt1963 : 5pcs parallel x4 step down config.
example:
1 stage: power regenerator
2 r core transformer
3 sigma 11,studer 900, or simple Schottky rectifiers
4 5x4 lt1963 12-9-7-5 v
5 lt3045 x4
Listening tests Matter!Other technical bla bla I don't care.
Develop ultra capacitor power supply and LiFePO4 battery power supplyHide this!Advertise here!
FS: ultra low noise power supply with 6 LT3045 Shutdown98 Swap Meet 1 13th June 2018 07:28 PM
Ultra Low Noise Lab Power Supply branadic Equipment & Tools 0 4th September 2017 06:02 PM
Battery power/power supply from wall charger for BT speaker satx Chip Amps 72 3rd July 2015 10:28 PM
Scavenging ultra low noise power supply jackinnj Power Supplies 3 7th September 2008 04:32 PM
