Develop ultra capacitor power supply and LiFePO4 battery power supply
Thread Tools
Old 31st December 2020, 08:38 PM   #1391
NicMac is offline NicMac  Italy
NicMac's Avatar
And now your system sounds much better?
Old 1st January 2021, 05:02 PM   #1392
eduard is offline eduard  Netherlands
Send a message via Yahoo to eduard
Hello,
It does but he likes it when being asked.
If it wasnt an improvement why tell us about it?
Greetings, Eduard
Old 1st January 2021, 07:06 PM   #1393
clsidxxl is offline clsidxxl  France
clsidxxl's Avatar
I have installed 2 UcConditioner 3V, 1 for the I2S to PCM board and another for the XO board,they are each installed with 8 centimeters of cable up to the load,the XO and I2S to PCM board were previously powered by 2 Maxwell 3000f 2.7 V but with a cable of more or less 30 centimeters,my preference is for the UcConditioner,improvement and evident in the bass and low medium and a slightly more defined midrange,thanks Ian and best wishes for 2021.
Old 1st January 2021, 08:23 PM   #1394
Hello Strassbourg,
When you read the French L'audiophile magazines from some decades ago you will know that once you start to use caps with extreme good specs you will have to pay extreme attention to everything in between these caps and the circuit to which they provide their energy.
I remember well how they wrote about cleaning the copper bars and using electrolube.
Greetings,Eduard
Old 1st January 2021, 08:50 PM   #1395
clsidxxl's Avatar
Thank you eduard, yes i knew it of course, and i made all of this sense during the implementation of UCconditionner, moreover Ian indicated it in the pdf,
I also read the new review of sound and i also the review of the audiophile, 35 years ago.
Old 3rd January 2021, 12:49 AM   #1396
iancanada is offline iancanada  Canada
iancanada's Avatar
I made a new ConditionerPi Video on YouYube, which is here:
ConditionerPi to Upgrade the Sound Quality of RaspberryPi Audio by Ultracapacitor banks 4K - YouTube
Happy New Year!
Ian
Old 3rd January 2021, 02:26 PM   #1397
Hello,
Including typical audiophile muzak.
Greetings, Eduard
Old 5th January 2021, 09:52 PM   #1398
Bagnolet is offline Bagnolet  Switzerland
Happy New Year!
Ian
Hi Ian, I did complete an order form and sent it to your email address. I want to try the conditionerPI and the LinearPi solo for my HifiBerry DAC+Pro, as an alternative to a ultra low noise PSU I'm using by now (THEL Black-Pulsar BLP 25-09) which already sounds very good, but gets very warm (class A device).
Old 10th January 2021, 06:34 PM   #1399
Gabster 2000 is offline Gabster 2000
Default Help with ground on lifepo4 causing ripple noise on fifo supply
Just realized that the negative rail from the 12-19v lifepo4 is connected to the stand-offs and since I am using a metal case it connects to the case.
Connecting the FIFO ground and other hats ( negative - pole 3.3v) to the ground connects it to the nasty 19v switching supply and start to get ripple noise on the 3.3v battery supply side see oscilloscope photo
1) should I lift the lifepo4 off the Metal case with plastic standoffs
2) not connect the fifo and hats negative pole to the metal case ground
3) what about the Pi negative is also connecting with ground
I am confused what is the point of isolating all the battery power supplies to connect them all together on their negative poles with nasty noisy equipment.
Any suggestions? What are you guys doing about ground? in a metal case environment.
File Type: jpeg BF813BFE-50AD-4EDD-940C-C743B2B58E63.jpeg (276.1 KB, 259 views)
Old 11th January 2021, 11:28 PM   #1400
A123 is offline A123  United States
Originally Posted by Greg Stewart View Post
For cut protection, there are cut-resistant Kevlar gloves. Here in the US, we get them from our local hardware store.
Thanks for this... Didn't have to dish out for expensive gloves.
Kevlar gloves really helping with my current project.
Develop ultra capacitor power supply and LiFePO4 battery power supplyHide this!Advertise here!
Thread Tools
FS: ultra low noise power supply with 6 LT3045 Shutdown98 Swap Meet 1 13th June 2018 08:28 PM
Ultra Low Noise Lab Power Supply branadic Equipment & Tools 0 4th September 2017 07:02 PM
Battery power/power supply from wall charger for BT speaker satx Chip Amps 72 3rd July 2015 11:28 PM
Scavenging ultra low noise power supply jackinnj Power Supplies 3 7th September 2008 05:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
