Develop ultra capacitor power supply and LiFePO4 battery power supply
Old 30th June 2020, 04:01 AM   #1121
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by yunyun View Post
@Ian,
ConditionerPi has the charging current limitation of 700mA to 1A?
Full empty starting charging current around 500mA or bit higher, this current will be slowly reduced while charging.
Ian
Old 30th June 2020, 04:11 AM   #1122
iancanada's Avatar
@Ian,
What is the difference between ultra capacitor full indicator and conditioning indicator? In this situation, what will it be the same, what will it be different?
They come from different logic. Normally they start at the same time or shortly after.
But when you turn of the on/off switch, conditioning LED will be off while full LED keep lit as long as UCs are full.
Ian
Old 30th June 2020, 03:52 PM   #1123
alecm is offline alecm  Sweden
it works...
thank you Ian!!
File Type: jpeg 71820B3D-A834-4AE7-818C-DF8966EDE33B.jpeg (109.3 KB, 223 views)
Soekris DAM 1021 MODS #1,#2,#3 and multi-channel Soekris project
Old 30th June 2020, 03:56 PM   #1124
iancanada's Avatar
Originally Posted by alecm View Post
it works...
thank you Ian!!
That's great! Thanks for the update.
Ian
Old 1st July 2020, 01:43 AM   #1125
yunyun is offline yunyun
@Ian,
Can I modify UcConditioner from 5V version to 3.3v? For example, change the resistance on UcConditioner?
I found that I bought the wrong version, I should buy two 3.3v. My original plan was to buy the 5V UcConditioner without removing the LDO from McDualXO. However, I forget that McDualXO will automatically skip LDO when the input power is 3.3v so I don't need to remove the LDO on McDualXO.
3.3v UcConditioner powers McDualXO and BUFFALO DAC at the same time, will it have a negative impact? 3.3v UcConditioner powers McDualXO and BUFFALO DAC at the same time If I cannot easily modify UcConditioner from 5V version to 3.3v.
Old 1st July 2020, 03:35 AM   #1126
iancanada's Avatar
@yunyun
You can, but not that easy. A lot of things need to be changed and I have not time to support.
They are not expensive and for one or two you can try normal letter mail without tracking number for more saving.
Ian
Old 1st July 2020, 04:40 AM   #1127
Originally Posted by iancanada View Post
@yunyun
Ian
3.3v UcConditioner with 3000F ultra capacitor powers McDualXO and BUFFALO DAC at the same time, will it have a negative impact?
Old 1st July 2020, 05:38 AM   #1128
@yunyun
Ian
I have a friend who works at a power supply company and he can help me. Can you tell me how to modify it?
Old 1st July 2020, 07:34 AM   #1129
mksung is offline mksung  Taiwan
UcConditioner installed on the clear side of fifopi can be heard the difference. There are two more sets of UcConditioner to see how to plan the configuration. thank.
Old 1st July 2020, 07:42 AM   #1130
it works...
thank you Ian!!
Is the discharge resistor installed at the power input?
Develop ultra capacitor power supply and LiFePO4 battery power supplyHide this!Advertise here!
FS: ultra low noise power supply with 6 LT3045 Shutdown98 Swap Meet 1 13th June 2018 07:28 PM
Ultra Low Noise Lab Power Supply branadic Equipment & Tools 0 4th September 2017 06:02 PM
Battery power/power supply from wall charger for BT speaker satx Chip Amps 72 3rd July 2015 10:28 PM
Scavenging ultra low noise power supply jackinnj Power Supplies 3 7th September 2008 04:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
