Develop ultra capacitor power supply and LiFePO4 battery power supply
Thread Tools
Old 7th May 2020, 08:46 PM   #1021
alazira is offline alazira  United States
alazira's Avatar
Ian, how about these puppies? Could these work for powering an amp?
HD Lifepo4 Battery For RV Solar Marine Boat | Polinovel
Old 17th May 2020, 08:18 AM   #1022
SimonJ is offline SimonJ  United Kingdom
Hello Ian,
Hope you are safe and well. Could you give a project status update on the new version and when you feel it might be ready for purchase please?
I know all this takes time and you need to bed in and test and the wait is worth it
Interested to know how you are progressing and my super caps are already purchased
Thank you
Old 17th May 2020, 10:03 AM   #1023
prohvesor is offline prohvesor  Ukraine
Ian is ok, but very busy with producing medical ventilators, big order for Canada. Our toys will be ready for order next week.
Old 17th May 2020, 10:10 AM   #1024
GREAT to hear all is well!
Producing ventilators is MUCH more important than our toys and now it’s clear why he has been quiet on here
Well done Ian for all your efforts at this difficult time in the world
Old 24th May 2020, 03:28 AM   #1025
iancanada is online now iancanada  Canada
iancanada's Avatar
Originally Posted by SimonJ View Post
Hello Ian,
Thank you
Thanks guys, Yes I'm really busy these days. But I still need time to take care my diyAudio projects.
I'll post some good news for you and trying to make them available soon.
Ian
Old 24th May 2020, 04:01 AM   #1026
iancanada's Avatar
Default UcConditioner V7.0
UcConditioner 5V design has been updated to V7.0 with big improvements.
1. Fully ultra low On-resistance MOS FET design. Get rid of relay.
2. Built-in constant current per-charge/charge circuits.
3. Built-in DC input detection and ultra capacitor monitoring circuits.
4. Control enable/disable conditioning automatically without any delay.
5. Control logic runs at back ground, no longer need any control signal. Just input and output. Really easy to use.
6. On-board active balancers to protect ultra capacitors.
7. Input: terminal connector and USB-C.
8. Output: terminal connector and USB-C.
9. With external ultra capacitor connector flexible for additional/external capacitors.
10. LED indications for power on, power good, ultra capacitor full and conditioning.
11. Double thickness PCB copper layer especially designed for high current and ultra low ESR applications.
12. MOS FETs controlled by optical isolators to eliminate any possible leakage current.
Testing result will be posted very soon.
UcConditionerV7_1
by Ian, on Flickr
Good weekend.
Ian
Old 24th May 2020, 08:22 AM   #1027
misterdog is offline misterdog  United Kingdom
Does anyone have a part number for the rotary encoder on the LiFeP04 please ?
Old 24th May 2020, 02:54 PM   #1028
iancanada's Avatar
Default UcConditioner V7.0 with ultra capacitors installed
Please see the UcConditioner picture with ultra capacitors installed.
Ultra capacitors P/N:
BCAP0325 P270 S17
BCAP0350 E270 T11
Both of them are very good. But I prefer the first one a little bit because of the lower ESR. In real listening test, lower ESR ones also sound better.
The pins of ultra capacitors are very strong. Have to use iron with power 80W or higher to solder them on to UcConditionerPi PCB. It also because of the 2oz PCB copper layer.
However, to remove them from PCB would be a big challenge. So, if you are new to ultra capacitors, I would suggest using the external capacitor connector first. You could solder them to PCB only after you confirmed everything is OK.
UcConditionerV7wUC_1
by Ian, on Flickr
Ian
Old 24th May 2020, 08:29 PM   #1029
marcus1 is offline marcus1
Can't wait to try it :>)
Originally Posted by iancanada View Post
Pleasesee the UcConditioner picture with ultra capacitors installed.
BCAP0325 P270 S17
BCAP0350 E270 T11
by Ian, on Flickr
Ian
Old 24th May 2020, 08:34 PM   #1030
lwr is offline lwr  United States
Smile Count me in too
Can’t wait to try it too
Develop ultra capacitor power supply and LiFePO4 battery power supplyHide this!Advertise here!
Thread Tools
FS: ultra low noise power supply with 6 LT3045 Shutdown98 Swap Meet 1 13th June 2018 07:28 PM
Ultra Low Noise Lab Power Supply branadic Equipment & Tools 0 4th September 2017 06:02 PM
Battery power/power supply from wall charger for BT speaker satx Chip Amps 72 3rd July 2015 10:28 PM
Scavenging ultra low noise power supply jackinnj Power Supplies 3 7th September 2008 04:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
