Power supply for phono stage
I ask for advice-you need a very good power supply circuit for a phono tube
preamp
2-tube ecc83 +2 tube ecc88. (attach)
advise the scheme. or a ready fee
250-- v. anode feed
6.3 -v heat
12 - v
I will buy a transformer for the needs of
I do not want to have an AC background
ok!!!!
who then applied this to the phono stage? really have reviews or read the article-there are comments of the person who applied it? in the phono stage?
I want to read the article - or see the photo!
Thank you so much!!! -It is very interesting !
can? to put a resistor to get 250 volts?
6) Current with 12V interface (No-load): 250mA
I did. Here's a much better circuit for phono I built. Yes, you can use an RC filter to get 250V.
EDIT: the one resistor that got too hot was due to a short. It still works fine, so I left it instead of changing it.
It's completely silent. If there was any noise (there isn't, I scoped it) it would be around 35kHz. The entire thing will run off of a battery if you want it to, too!
I use SMPS and boost on most of my builds. Yesterday I built a 6P45S triode connected amp (80W) powered from an ATX supply and a 500W boost converter :) Even the module I listed above set to 110V for negative bias. (it's isolated)
I also built a GU-29 amp using these. They work better than linear and cost less to use. Win/win if you ask me :)
