LOFO Pre/Power Amp Switch
Old 10th August 2018, 03:16 PM   #1
quyda is offline quyda  Viet Nam
Default LOFO Pre/Power Amp Switch
Is there a simple switch that will turn Preamp & Power Amp in correct order, that is Power Amp = Last ON, First OFF (LOFO)?
Im a lazy *** and one a foolproof way to turn my equipments.
Thanks,
Quy
Old 11th August 2018, 11:07 AM   #2
DF96 is offline DF96  England
You may be able to find a 3-position toggle switch, or a mains-rated rotary switch.
Old 11th August 2018, 07:27 PM   #3
Im thinking about Arduino + 2Ch relay, but im not sure about when the main power was suddenly cut off to the relay board, both relay will probably go off at the same time.
Old 11th August 2018, 08:32 PM   #4
rayma is offline rayma  United States
= Last ON, First OFF (LOFO)? Im a lazy *** and one a foolproof way to turn my equipments.
Use a regular switch and an LM555 timer controlling an AC relay, for adding time delay for the amp.
The LM555 should immediately reset upon power off, to deal with AC power line drop outs.
All you really need, though, is delayed unmuting on the preamp outputs. Then both preamp
and amp can be safely switched on at the same time. The LM555 should immediately reset
What kind of amp/preamp is this for?
Old 12th August 2018, 03:12 AM   #5
Im running my L15-D after a JC-2 (purely for volume control atm).
Problem is when cut off power of both amp at the same time, the JC-2 would give a loud thump.
But the LOFO setup that I want can be use with any pair of Amp/Pre.
Old 12th August 2018, 03:19 AM   #6
It's a China JC-2 clone? I have one of those. I think the arrangement in post 4 would work for you,
just add the circuit in an external box.
You can add a pass-through box with a series resistor and a shunt relay to ground, controlled by
the LM555. This box would need its own power supply. The timer should reset immediately upon
turnoff, to deal with AC line dropouts.
You would plug the box's power cord into a switched AC outlet on the preamp, so the box can sense
that the preamp power has been switched. Or if you use an outlet strip to switch everything, plug
the box into that.
There are commercial AC sequencing boxes made for this kind of purpose, Audio Research made some
rather expensive ones years ago.
LOFO Pre/Power Amp SwitchHide this!Advertise here!
Amcron DC300A replace power switch with 2 wire switch simondolanbass Solid State 3 11th September 2017 02:07 AM
Capacitor Across Power Switch to Control Switch On Noise? DreadPirate Analog Line Level 20 21st April 2013 03:58 PM
Power switch driver board(Momentary switch) + output relay board(delayed ON/fast OFF) Neutrality Headphone Systems 1 20th March 2013 11:57 AM
Adding a 12V power trigger switch to Electrocompaniet Power Amp maxzimum Solid State 0 11th April 2008 02:54 PM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 09:23 PM
Copyright ©1999-2019 diyAudio
