Primaluna's AC Offset Killer
Old 2nd June 2018, 06:45 PM   #21
basreflex is online now basreflex  Spain
ltspice tell me the the workings of the circuit.
the diodes act as a threshold for the dc component. without the diodes (rsw=1mohm 1A as the 10H coil is 1ohm).
with the diodes much less not zero , but tolerable.
Old 2nd June 2018, 07:16 PM   #22
Alexandru is offline Alexandru  United States
Thanks for sharing.
Any reasons for choosing MURS320 instead of STTH12R06FP?
Old 2nd June 2018, 07:53 PM   #23
freddi is offline freddi  United States
freddi's Avatar
how about a MUR1560 for the 4 diode circuit? (Crown amp rated 1KW/ch 8 ohm) - those are in the $2.50 range - is there something cheaper?
Old 2nd June 2018, 08:27 PM   #24
just took a diode available in the LT library that was 3A to demonstrate the operation. take any diode you like. you need more diode pairs if the dc offset is larger, and dissipate more in the diodes.
the offset might originate from unbalanced loads elsewhere in the grid.
Old 4th June 2018, 06:24 AM   #25
It looks like PS Audio has a device that harvests the DC noise and converts it into light.
The owner explains how it works: Youtube1 Youtube2
It's called Noise Harvester and it looks like this:
Old 4th June 2018, 08:24 AM   #26
tomchr is offline tomchr  Canada
tomchr's Avatar
I hope that's an April Fool's joke rather than an actual product.
Modulus-86, 186, 286, 286 Kit, & 686: 40-240W (8Ω) at <-120dB THD. HP-1: 3W/20Ω, -130dB THD, 128dB DNR.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 4th June 2018, 08:42 AM   #27
could be a handy tool for audio contractors. in a theartre it is important to connect your amp to a power socket that is not dimmed. this indicator does trigger on the noise spikes of a dimmed socket. a simpler option is a small cap to a neon bulb.
Old 4th June 2018, 09:12 AM   #28
tomchr's Avatar
Yeah. But there's no way it converts noise to light, thereby completely eliminates the noise as claimed in the video. Physics would get in the way of that rather quickly.
Tom
Old 5th June 2018, 08:37 PM   #29
Paul from PS Audio says it was a designed by one of their mad scientists and they are very proud of this unique product. Well, they says it eliminates noise..but not completely..that's why you probably need more than 1.
Can anybody measure these claims?
Old 9th June 2018, 05:45 AM   #30
I've found another DC offset blocker. It looks very similar to Primaluna's isn't it?
Primaluna's AC Offset KillerHide this!Advertise here!
PrimaLuna Prologue Two Inductionist Tubes / Valves 7 16th October 2017 07:01 PM
PrimaLuna; Phonologue board subst. Inductionist Analog Line Level 0 13th October 2016 08:08 PM
Primaluna redesign knobs Inductionist Parts 3 22nd September 2016 06:43 PM
Please Help: CDP Primaluna P8 for repair farl Digital Source 3 12th September 2010 08:08 PM
primaluna dialogue 5 and fanboys? lvas12 Tubes / Valves 0 1st February 2009 05:39 PM
