Salas SSLV1.3 UltraBiB shunt regulator
Old 21st July 2018, 08:59 AM   #331
Swarky is offline Swarky  Canary Islands
Originally Posted by fedde View Post
You can use a lower voltage capacitor for C1. However, I think 5V is the minimal output voltage so you cannot do -3V...
I was under the impression it was symmetrical on the negative board and if necessary to use an LDO as in my application (Hagerman piccolo mc step up) it wouldn’t detract too much from the lower noise levels because it was on the negative rail.
Old 23rd July 2018, 09:30 AM   #332
MagicBus is offline MagicBus  Greece
MagicBus's Avatar
Here is my little power station... 3,3V x2, 5V x2 , 10V x2. All grounds only meet at the obscure object of desire!
Old 23rd July 2018, 10:58 AM   #333
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by JOIMONF View Post
Looking at schemantic on build guide, I think it's a mistake:
''For CC <1A M1 IRF9610...''
Instead of less ''<'', does should not be more ''>''?
The IRF9610/610 at M1 position are trusty enough as alternatives to the listed Fairchilds for below 1A constant current at about 5V across them. Still their core to case thermal resistance is significantly higher and their positive/negative type curves are not as close but they develop less VGS voltage while being easier to find and as fast or little faster for parasitic capacitance.
Old 23rd July 2018, 11:01 AM   #334
Salas's Avatar
Very nice
Old 23rd July 2018, 11:03 AM   #335
Salas's Avatar
The negative 1.3 reg section can go down to around -5V DC output
Old 23rd July 2018, 12:32 PM   #336
MagicBus's Avatar
Originally Posted by Salas View Post
Very nice
Thanks Salas!
Old 23rd July 2018, 04:38 PM   #337
JOIMONF is offline JOIMONF
JOIMONF's Avatar
Congratulations for this new reg. Salas, thanks for share and help.
I was confused, excited to find out, I read this thread on one sitting.
Now I learned that there are TWO substitutes for M1, for less than 1A. IRF9610. And then for high current, IRF9640. Ok. Ok.
Other than to power a DCB-03 preamplifier, and a 14v. Tripath chip amp., my plan is also use one UltraBiB as a prereg. set it at 7v. and then chain it to a several 500mA. modules ultralownoise 0.8mV. postregulators LT3405. These I got plenty and cheap on Taobao site. Are claimed a flexible voltage dropout between 1V. and 4V. So theoretically I could power many 3,3v and 5v. gizmos I have in my USB chain: Filters, hubs, memory sticks, clocks, etc.
Old 25th July 2018, 01:52 AM   #338
JOIMONF's Avatar
50R as R3 is also acceptable?
Old 25th July 2018, 06:52 AM   #339
Salas's Avatar
Yes
Old 25th July 2018, 04:49 PM   #340
JOIMONF's Avatar
thanks!
Salas SSLV1.3 UltraBiB shunt regulatorHide this!Advertise here!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1674 8th June 2019 07:08 PM
FS: Salas SSLV1.1 BiB shunt regulators Rudi_Ratlos Swap Meet 2 2nd April 2018 04:20 PM
WTB: Salas SSLV1.1 BiB shunt reg KevinHeem Swap Meet 1 12th February 2015 06:04 PM
WTB: Salas SSLV1.1 BiB shunt reg positive board sbelyo Swap Meet 1 29th December 2014 04:17 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 10:43 AM
Copyright ©1999-2019 diyAudio
