Salas SSLV1.3 UltraBiB shunt regulator
Old 14th September 2019, 05:41 PM   #1751
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by shattered_dream View Post
Hmmm is a heatsink temperature of 46C ok?
Yes its a comfortable temperature for the semiconductors.
Old 14th September 2019, 07:15 PM   #1752
rickmcinnis is offline rickmcinnis  United States
A question concerning those who are using the SALAS board for Soekris DACs:
There are small inductors at the inputs for the power supplies.
What does the regulator think of having an inductor in the path?
It would be easy enough to bypass these if it would be better.
Any thoughts and recommendations?
Thanks,
Old 14th September 2019, 08:27 PM   #1753
Salas's Avatar
I had tested it with long lab leads which represent some inductance besides some resistance and it was fine. To check for specific situations use the scope. If the rails are calm straight lines in AC coupling 5mV vertical & 50uS horizontal settings everything should be fine. Use the short earth (coil like) probe's nose accessory.
Prefer the more stable technical result. If the rail shows as stable with input coil as with bypassed input coil, then its down to subjective preference keeping it in circuit or not.
Old 15th September 2019, 01:47 PM   #1754
Thanks for your guidance.
Old 15th September 2019, 05:01 PM   #1755
samoloko is offline samoloko  Bulgaria
Salas,
what Is first choice for pf5102 substitute
sk170 of other jfet
which Idss
Old 15th September 2019, 07:25 PM   #1756
Salas's Avatar
Read post#1559
Old 28th September 2019, 08:27 PM   #1757
nashbap is offline nashbap  United States
Hi Salas,
I would like to know for what applications a shunt regulator like the UltraBib 1.3 is best suited for. And what is it about these shunt regulators as compared to the three legged ones that make them sound so special.
I am considering building Pete Millett's Nutube balanced line amp and was wondering if the UltraBib 1.3 would be a good fit here.
Nutube Balanced Amp
A +/-15v supply the board draws about 15mA from the +15V supply, and 75mA from the -15V supply (which also powers the filament). This is for each channel, so I would go with two of them.
Appreciate your input.
Thanks. nash
F5TV3, AVC, BA3b pre, Salas DCG3b, OBL-15, SonyVfet2pair monos
Old 28th September 2019, 09:37 PM   #1758
Salas's Avatar
CCS fed shunts (AKA super shunts) like the UBiB, are easier to use with relatively steady current drawing low to medium power clients. So the CC limit to load current ratio is predictable and moderate for good settings regarding spare current, stability, and dissipation.
Shunts both give and soak up power when series only give. Such shunts refer power to the output node. The main CCS isolates things located before their parallel voltage circuit. Excess current is constantly burned at the output so they are surely not "green". To the contrary. Loosely described sometimes as the Class A amps of the PSUs world. Those are general characteristics, their special qualities vary per design.
So they differ in architecture to normal three pin regs. Consequently they have their flavor and their followers.
All client circuits within the voltage and current envelope described in the build guide are UBiB powered candidates. I would set 125mA CC in the positive and 200mA in the negative for your example if double mono. For common between channels PSUs I would set 150mA CC pos 270mA CC neg.
Old 29th September 2019, 02:49 PM   #1759
Thanks for the straightforward explanation. Yes, I am a follower and love the flavor!
25 or 50VA transformers for dual mono? Antek seems to make the shielded AS series only for the 50VA. Dont know why.
In the example that I am considering, the +15v feeds the Jfet followers and the anode plate but the -15v is lowered to 5v by a LM317MTG to feed the grid and then another LM317MTG lowers the voltage further to feed the heaters. Do these subsequent LDO regs constrict the flavor of the shunt PSU?. Or would dropping resistors be a better choice?
Nash
Old 29th September 2019, 07:11 PM   #1760
Salas's Avatar
Buy the 50VA ones IMO, they are better made and not expensive.
The shunts usually show some of their traits as pre-regulators too so listen first and then modify the negative rail internal arrangements if you feel its a must.
But ask the designer of that preamp circuit if he agrees and on how to do it best with passives or differently.
The grid bias feed (-10V) arrangement should be the main quality consideration I suppose.
Salas SSLV1.3 UltraBiB shunt regulatorHide this!Advertise here!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1674 8th June 2019 06:08 PM
FS: Salas SSLV1.1 BiB shunt regulators Rudi_Ratlos Swap Meet 2 2nd April 2018 03:20 PM
WTB: Salas SSLV1.1 BiB shunt reg KevinHeem Swap Meet 1 12th February 2015 05:04 PM
WTB: Salas SSLV1.1 BiB shunt reg positive board sbelyo Swap Meet 1 29th December 2014 03:17 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
Copyright ©1999-2019 diyAudio
