Salas SSLV1.3 UltraBiB shunt regulator
Old 18th August 2019, 02:49 PM   #1691
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Alypius View Post
Just getting started with my spiffy new UltraBiB boards! In the spirit of DIY, I'm going through my inventory of bits and I have a few 10kuF/63V caps. Is there any issue using those for C1? I know the guide calls for 6800uF/50V; I'm running two 24+24 transformers for a dual-mono BA-3 preamp, so the current isn't going anywhere near 1A. I don't think upping C1 to 10k will harm anything, but I'd like the expert confirmation. Thanks!
Its OK to use a bigger reservoir capacitor when you have it.
Old 18th August 2019, 05:57 PM   #1692
manniraj is online now manniraj  India
Originally Posted by Salas View Post
Check R5 R6 are the right value. The drop across R5 is also Q2's Vbe and its very little. Replace Q2 Q3 J2 to make sure.
I replaced the Q2,3 with 550C and J2 from my spare positive board kit P5102. Checked R5,6 and they are as per spec 270R. Still the voltage is stuck at -9.9vdc. Below are the readings for your reference.
Vbe across q4 = 1v
Vbe across q2 = 0.34v
Vbe across q3 = 0.51v
Vbe across q1 = 0.56v
Voltage drops on R5 = 0.14v
Voltage drops on R7 = 0.29v
Old 18th August 2019, 08:15 PM   #1693
Salas's Avatar
How much is the voltage drop across R1's pins? How much is the raw DC voltage across C1's pins?
Old 19th August 2019, 01:42 AM   #1694
dewdrop is online now dewdrop
You might want to check for cold solder joints for the caps because of the thick copper ground trace. Worthwhile to go through these again.
Ed
Old 20th August 2019, 01:00 AM   #1695
Thanks guys will check that over the weekend and report back.
Salas SSLV1.3 UltraBiB shunt regulatorHide this!Advertise here!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1674 8th June 2019 06:08 PM
FS: Salas SSLV1.1 BiB shunt regulators Rudi_Ratlos Swap Meet 2 2nd April 2018 03:20 PM
WTB: Salas SSLV1.1 BiB shunt reg KevinHeem Swap Meet 1 12th February 2015 05:04 PM
WTB: Salas SSLV1.1 BiB shunt reg positive board sbelyo Swap Meet 1 29th December 2014 03:17 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
Copyright ©1999-2019 diyAudio
