Salas SSLV1.3 UltraBiB shunt regulator
Old 19th April 2019, 08:28 PM   #1431
miksi is offline miksi  Serbia
Thanks.
Old 22nd April 2019, 01:14 PM   #1432
sumeshak is offline sumeshak
Default PSU deisgn---Help please
Sir,
I sent a PM...Kindly check.
Sumesh
Originally Posted by Salas View Post
Lets say to J1
Old 27th April 2019, 11:11 AM   #1433
beardman is offline beardman  Denmark
A little questions.
i am soldering the 15v + - board
on the minus board there were green led from Tea
on the plus board there were green and red led from Tea
shall i use red or green on the plus board
best Bjarne
Old 27th April 2019, 11:24 AM   #1434
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
For this kind of voltage it does not technically matter. Green on both to visually match (?)
Old 27th April 2019, 11:28 AM   #1435
Good to know....then i will use red on plus and green on minus....looks good
Old 27th April 2019, 11:42 AM   #1436
Salas's Avatar
Alright
Old 27th April 2019, 06:15 PM   #1437
board is op and running
have now run for more hours....drift about 0.3vdc down from 15vdc
i have no resistor to load the supply with ..so i test it without
R1 is 2 ohm
cooling is good ..easily holding on the heatsink---
will the dc voltage go up when i mount my load ??
so close to testing on my Mirand dac
Old 27th April 2019, 06:33 PM   #1438
Salas's Avatar
It could show little less drift due to less heat from M2 because of power sharing with the load but not much. That drift is its normal thermal settling before going steady in this voltage area. Better allow for it in set up anyway.
Old 27th April 2019, 09:51 PM   #1439
some problem with connection
i shall use 15+ 0 -15
when i mount the 2 0 volt together the regulator goes out on the led on positive and negative board
works fine without the 2 0 volt mounted together
is there something in the wiring i have done wrong ?
Old 27th April 2019, 10:56 PM   #1440
Salas's Avatar
If they got a common sink check the Mosfets insulation
Salas SSLV1.3 UltraBiB shunt regulatorHide this!Advertise here!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1674 8th June 2019 06:08 PM
FS: Salas SSLV1.1 BiB shunt regulators Rudi_Ratlos Swap Meet 2 2nd April 2018 03:20 PM
WTB: Salas SSLV1.1 BiB shunt reg KevinHeem Swap Meet 1 12th February 2015 05:04 PM
WTB: Salas SSLV1.1 BiB shunt reg positive board sbelyo Swap Meet 1 29th December 2014 03:17 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
Copyright ©1999-2019 diyAudio
