Salas SSLV1.3 UltraBiB shunt regulator
Old 31st March 2019, 08:31 PM   #1351
pistollero is offline pistollero  Portugal
All salas power... only missing the amp and rpi ps....(maybe one day)
Old 31st March 2019, 11:26 PM   #1352
dewdrop is offline dewdrop  Singapore
Originally Posted by Salas View Post
I had finished and breadboarded the design one to two months ago. Its CRT who's scarce this period so there is delay finishing the PCB details. Working on it on and off. But last time we communicated he showed progress, had got the guidelines right this time, and he is in final stages.
Great. I need a good PS for my Pi.
Ed
Old 1st April 2019, 06:03 AM   #1353
nano35 is offline nano35  Hong Kong
Hi Salas and Pi3 members,
Sorry I forgot to do a follow-up.(from post#1306)
The simple answer is No, it did not work.
After playing music nicely for an hour, the Pi3 started to lose track of the music files and show nothing on the playlist.
I restarted and all led lights blinked, dim and out.
I put back the old LT3045+Lt1963 regs and Pi3 worked as usual.
I tested the BiB board on other devices and it worked.
(relief!)
An interesting scenario I found here:
When I plugged pi3+BiB in my kitchen for testing, it booted and showed the music app interface as normal; when I plugged in with my rest of HiFi in my room, it failed with led lights all dimmed or out.
Later I discovered that in my room, I plugged in also the USB cable(to Dac) or/and ethernet plug to my MacBook Pro, immediately the Pi and BiB reg's led lights all got dimmed and/or out and not booting.
I wonder if it is the DAC USB cable/ethernet cable that draws too much power to render the whole thing un-bootable.
My BiB is now a very good stable reg for my SSD expansion board(for Pi3) which requires 5V/3.5A to be stable. (before it has the similar symptom of suddenly not showing music files)...been working for many days without problem.
Can't wait for Salas' new L-Adaptor Reg
Old 1st April 2019, 07:42 AM   #1354
Dimdim is offline Dimdim  Greece
Your transformer is too weak for the CCS current that you are pulling, or at best marginal.
50VA at 9V means about 5A of AC current which translates to a bit over 3A of DC current, perhaps a bit more if the transformer is a bit overengineered.
If I were you I'd try increasing R1 to 0.3R and see if that improves stability. 2A of CCS current should be more than enough in any case for an RPi with no extreme peripherals.
http://www.dimdim.gr
Old 1st April 2019, 12:21 PM   #1355
Thanks dim dim. I will give it a try.
Old 1st April 2019, 01:20 PM   #1356
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Are those RPI so weird? Alexkosha wrote that his does not work correctly on his HP bench supply even. Maybe they want mains earth grounding?
Old 1st April 2019, 01:53 PM   #1357
arduinovie is offline arduinovie  Viet Nam
arduinovie's Avatar
i sent picture Board SSLV 1.3 BIB
Old 1st April 2019, 02:03 PM   #1358
In my experience they are not that weird. I believe that the problems might be caused by voltage drop on the cables / connectors. It might be a good idea to bump up the voltage to ~5.2V on the UBiB's output in order to compensate for any voltage drops. The RPi won't mind the (potentially) slightly higher voltage.
The RPi definitely does not need mains ground. It is designed to be powered by a cheap non-grounded smps.
Old 1st April 2019, 02:27 PM   #1359
Salas's Avatar
You made that pcb?
Old 1st April 2019, 02:57 PM   #1360
arduinovie's Avatar
You made that pcb?
dear Mr.Salas!
In Vietnam we also have DIY groups, a friend in the group who has drawn a circuit he has provided on 4R diyaudio, because Vietnam is not favorable for the supply of components, so DIY has many difficulties and difficulties. suing China - poor quality available and very cheap.
To have good components to use DIY high quality products is quite difficult.
The cost of buying components is not cheap, so DIY groups often draw their own circuits to help DIY's brothers
Thanks again to Mr.Salas and longtime members on forum diyaudio.
Salas SSLV1.3 UltraBiB shunt regulatorHide this!Advertise here!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1674 8th June 2019 06:08 PM
FS: Salas SSLV1.1 BiB shunt regulators Rudi_Ratlos Swap Meet 2 2nd April 2018 03:20 PM
WTB: Salas SSLV1.1 BiB shunt reg KevinHeem Swap Meet 1 12th February 2015 05:04 PM
WTB: Salas SSLV1.1 BiB shunt reg positive board sbelyo Swap Meet 1 29th December 2014 03:17 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
Copyright ©1999-2019 diyAudio
