Salas SSLV1.3 UltraBiB shunt regulator
Old 11th March 2019, 01:45 PM   #1281
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by wengtech View Post
hello Salas,
why not using copper pour on your v1.3 pcb?
are there any disadvantages of using copper pour compared to single traces?
isn't the ground path bigger more better?
thanks.
Not to create further potential return current routes since I was content for noise and stability behavior with those of the test board's bottom ground plane. The return currents naturally try to find the closest path back under the send components routes and this ground plane is largely unbroken by bottom layer lanes, not hindering simple going return paths formation, so I decided to avoid over-complication with the grounding in yet another dimension. I specified thick copper for lower impedance. This level of material also gives some headaches to potential rework with weaker de-soldering techniques is an unfortunate side effect, as the thick continuous ground plane has increased thermal capacity and dissipates spot applied heat fast.
Old 14th March 2019, 07:30 PM   #1282
delfimmarues is offline delfimmarues  Portugal
Sharing my experience.
With my system Dam1021 / Raspberry 2B / Salas SSLV1.3 in full operation for weeks, I was quite happy with the result, but I came across the same problem reported by several forum members ... the Salas SSLV1.3 that feeds raspberry It kept very hot and could not close the box with risk to underheat.
My system:
Sedlbauer RSO-825007 2x 0-9v (Raspberry Pi 2B)
Sedlbauer RSO-825008 2x 0-12v (SSLV1.3 Rooms)
1. Salas SSLV1.3 5V (R1 0,57 2W; R9 1K)
2. Salas SSLV1.3 +/- 12V
Raspberry Pi 2B
Dam 1021
He had tried replacing Raspberry PI 2B with Raspberry PI 3 B but did trn on (apparently Raspberry PI 3B requires more current).
As a matter of space, I bought a new transformer, a Noratel TI083474 AU, that I do not know the specifications, except the outputs: 9.6v-0-9,6v; 12v-0-12v; 13.6v-0-13.6v.
After replacing Sedlbauer with Noratel ... to my surprise ...
I was able to connect to Raspberry 3B, with the same configuration as the previous BIB (which did not work!) ...
No heating checked on BIB 5V so far ....
How can I explain? Must you explain?
Old 14th March 2019, 08:58 PM   #1283
sangarfe is offline sangarfe  Spain
Default My project
The first thing Salas is to thank you for this great project that you have shared with us .
I also wanted to show you some pictures of how I did it.
The purpose of the power supply is to feed a preamplifier with RIAA correction for a turntable.I have not used the original PCB and I have designed a custom for the box and that also contains the preamplifier.
The transformers and rectifiers I have mounted in another separate box and physically separated from the one that contains the preamplifier. I also include the turntable motor power supply.
Any criticism or observation will be welcomed
Old 14th March 2019, 09:17 PM   #1284
Salas's Avatar
Fully handmade DIY is always nice to see. Does it work well as a whole without noises and giving a good sound? If yes, its a success.
Old 14th March 2019, 09:23 PM   #1285
Salas's Avatar
For bridge rectification the AC current output rating of a transformer must be de-rated at about -40%. Maybe your new transformer has the edge in current output over the previous one and that shows upon the boot.
When the rectification and reservoir capacitor part of the 1.3 starts it has an inrush current peak. All together with the boot momentum of the RPI3B maybe left the previous transfo bit breathless (?)
Old 15th March 2019, 05:40 PM   #1286
Thanks Salas.
This RIAA preamplifier is connected to an 80 + 80W Exposure amplifier. It does not have the slightest hum.
Only at the top of the volume is heard a shhhh that is appreciated by bringing the ear to the speakers. I attribute it to the opamps that I use, an OPA2134.
It's possible?.
As for the sound, it seems extraordinary to me, but I do not have to compare it
Old 15th March 2019, 08:45 PM   #1287
Salas's Avatar
Hiss noise level to stay satisfactory low when with the 8nVrtHz JFET input OPA2134 depends on a. Phono gain to be moderate b. Cartridge impedance to be high c. Total system voltage gain to be moderate d. Speakers sensitivity to be moderate
a & b are pointing to MM cartridge type is better for use with that chip.
So yes, that little hiss is due to the chip. In your case very well controlled while no other noises like hum & buzz are present.
Actually you could afford to test with even worse nVrtHz spec chips, since based on your description, there should be not much detectable hiss at the listening seat on any sane volume control position. AD823 is a direct substitution that I would recommend for a different taste of sound vs OPA2134.
Between those two usually contrasting types of presentations see which one you prefer.
Lower noise JFET input op-amps than the 2134 are not many and usually single type. Like the famous OPA627 if you like the Texas (BB) school. Less expensive is ADA4627 which is roughly analogous. When a circuit has been designed with a JFET input opamp in mind don't substitute with bipolar types.
Old 17th March 2019, 11:28 AM   #1288
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Hi, check Q2, Q3 Vbe. If not about 0.6V replace.
Q2 and Q3 replaced and everything works like charm.
Thanks Salas!
Old 17th March 2019, 12:23 PM   #1289
TioFrancotirador is offline TioFrancotirador  Poland
Originally Posted by samoloko View Post
you are using ultra BIB to power supply op amps and analogue power supplys for AK4497?
and for digital part - Reflecor D as pre regulator?
Yes exactly.
Old 17th March 2019, 08:54 PM   #1290
I thank you again for your attention and your advice Salas.
My theoretical knowledge, are not comparable to yours, but I am glad to have been successful in the diagnosis of noise in my preamp.
The solution of replacing the opamp with an AD823, is cheap and I will be able to use it to see the difference in sound.
Now that I write about this topic and, apologize for my complete ignorance, I wanted to ask you for an opinion about the devices that I have found browsing the Internet: "Audio Discrete Dual Op Amp HiFi Operational Amplifiers OP-AMP replace NE5532". Like the ones you can see at this address:
Audio Discrete Dual Op Amp HiFi Operational Amplifiers OP-AMP replace NE5532 358962406201 | eBay
Could it be a solution? Is it worth the change?
Thanks for your time
Salas SSLV1.3 UltraBiB shunt regulatorHide this!Advertise here!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1666 24th June 2018 05:30 PM
FS: Salas SSLV1.1 BiB shunt regulators Rudi_Ratlos Swap Meet 2 2nd April 2018 03:20 PM
WTB: Salas SSLV1.1 BiB shunt reg KevinHeem Swap Meet 1 12th February 2015 05:04 PM
WTB: Salas SSLV1.1 BiB shunt reg positive board sbelyo Swap Meet 1 29th December 2014 03:17 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
Copyright ©1999-2019 diyAudio
