Salas SSLV1.3 UltraBiB shunt regulator
Old 24th February 2019, 09:40 AM   #1231
dewdrop is offline dewdrop  Singapore
Looks very good!
Ed
Old 24th February 2019, 09:54 AM   #1232
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Looking like it means business. Its also good that he used thick enough cabling between the PSUs and the Soekris input power connector. Something that not all remember to do all the time.
Old 24th February 2019, 10:24 AM   #1233
RainfallSky is offline RainfallSky  Russian Federation
RainfallSky's Avatar
What would be the best M1 and M2 transistors for DCG3?
I guess DCG3 is always below 1A.
Some random comparisons:
M1 Positive:
FQP3P20 (Ciss 190 pF, -2.8 A)
IRF9610 (Ciss 170 pF, -1.0 A)
M2 Positive:
IRF530 (Ciss 670 pF, 10 A, Gfs 5.1 S)
IRF620 (Ciss 260 pF, 3.3 A, Gfs 1.5 S)
IRF610 (Ciss 140 pF, 2.1 A, Gfs 0.8 S)
M1 Negative:
FQP3N30 (Ciss 175 pF, 3.2 A)
IRF610 (Ciss 140 pF, 2.1 A)
M2 Negative:
IRF9530 (Ciss 860 pF, -8.2 A, Gfs 3.7 S)
IRF9620 (Ciss 350 pF, -2.0 A, Gfs 1.0 S)
IRF9610 (Ciss 170 pF, -1.0 A, Gfs 0.9 S)
Old 24th February 2019, 10:45 AM   #1234
Salas's Avatar
M1 can alternatively be IRF9610/IRF610 (pos/neg) when below 1A setting. It also consumes less gate to source voltage. So good enough for DCG3 UBiB PSU use. The FQP3P20 is good up to 1.77A when well hot, its 2.8A headline spec is at an optimal 25C core temperature. That is why I spec the regs at 1.5A max before considering slower but more powerful M1 types like the IRF9630/IRF630. So to stay on the conservative side.
M2 is always IRF530/IRF9530 (pos/neg) due to correct open loop gain phase margin considerations. IRF630/IRF9630 could be their only secure alternative for maintaining correct stability margins in these circuits. Theoretically so because I haven't tested them on an actual UBiB PCB as M2.
Old 24th February 2019, 10:55 AM   #1235
Got it. Thank you, Salas!
P.S.: Yes took wrong Ampere numbers from FQP3P20, FQP3N30.
Old 24th February 2019, 11:00 AM   #1236
Salas's Avatar
See you at the DCG3 thread then with a pre-amp build made in Peter to show
Old 24th February 2019, 11:22 AM   #1237
I will.
You know. This is how we call our city in short.
One last question.
Is it a bad thing to mix IRF5** and IRF6** series?
M2 Positive Board:
IRF630 (Ciss 800 pF, 5.7 A, Gfs 3.8 S)
M2 Negative Board:
IRF9630 (Ciss 700 pF, -4.0 A, Gfs 2.8 S)
IRF530 seems like a beter at Ciss and IRF9630 seems beter overall (for DCG3).
So can M2 Pos IRF530, M2 Neg IRF9630 be used?
Old 24th February 2019, 11:57 AM   #1238
Salas's Avatar
Its not bad to mix when the pF are close. The gfs S (Siemens) are closer at low current on the curves too.
Old 24th February 2019, 12:01 PM   #1239
Salas's Avatar
P.S. For correct current setting of dual UBiBs as coming from the DCG3 thread, remember:
"Rule of thumb for knowing you always got 100mA reserve, massaging the particular shunt regs to good effect in all DCG3 uses, is: Negative rail R1 setting = DCG3 bias level +100mA. Positive rail R1 setting = 2xDCG3 bias level + 100mA. Sinks size must be adequate. The UBiB's MOSFETS are tough but for robust reliability better not have more than 60C on their sinks in the long run. With so much high idling circuitry in a box, good ventilation is a must too."
Old 24th February 2019, 12:21 PM   #1240
nashbap is online now nashbap  United States
Salas what do you suggest is thick enough AWG?
Thanks. nash
F5TV3, AVC, BA3b pre, Salas DCG3b, OBL-15, SonyVfet2pair monos
Salas SSLV1.3 UltraBiB shunt regulatorHide this!Advertise here!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1674 8th June 2019 06:08 PM
FS: Salas SSLV1.1 BiB shunt regulators Rudi_Ratlos Swap Meet 2 2nd April 2018 03:20 PM
WTB: Salas SSLV1.1 BiB shunt reg KevinHeem Swap Meet 1 12th February 2015 05:04 PM
WTB: Salas SSLV1.1 BiB shunt reg positive board sbelyo Swap Meet 1 29th December 2014 03:17 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
Copyright ©1999-2019 diyAudio
