Kanged switching power supply for a tube amp.
Thread Tools
Old 8th April 2021, 11:22 PM   #121
kodabmx is offline kodabmx  Canada
Spreading triode love.
kodabmx's Avatar
As long as it has some balls on 12V, you're good
I offer circuit boards, kits, and complete systems for DIY vacuum tube audio.
Old 9th April 2021, 05:41 AM   #122
Alashikata is offline Alashikata  United States
500W Inverter:
Have you tested other combination to see what other V beside the list as 160 220 and 380. Wonder if can get 280 or 300 on this module.
Old 9th April 2021, 04:18 PM   #123
kodabmx's Avatar
160 into a Delon will give you 320, you can wire the 18V output in series with the 160 to either boost or buck.
Old 9th April 2021, 07:31 PM   #124
Great, I will get 2 boards 280 & 320 to test out.
Old 10th April 2021, 11:48 PM   #125
Have anyone ever thought of PS from satellite box? It should have enough to power to run this project. I have seen people give them away on Craigslist everyday I haven't checked others old home audio equipment yet but I believe they all standard design with 12v, 5v, and 3.3v.
Seem like all wires that has the same voltage connect to the same terminals so you only need to hook up 1 wire for the voltage need and whatever the current of the device need, it will draw enough to run until it runs out the current.
Here is my test on old satellite box PS, 12v and 5v are perfect for the tubes filament where it can run without fan. It would be great to use the satellite case as well since all the RCA and PS jack holes in the back are setup.
Old 16th June 2021, 10:27 PM   #126
craftyjam is offline craftyjam
Wow thank you for all of this info Kodabmx!
Just to be crystal clear, should the 12v ground be connected to the ht ground and the chassis? I currently have only the ht and 12v grounds isolated and im getting significant hum.
Old 22nd June 2021, 03:36 PM   #127
kodabmx's Avatar
You're welcome.
I tie the grounds together even to signal and chassis most of the time.
Old 26th June 2021, 04:10 AM   #128
Hello, one more question for ya:
How do you keep the hum from the 150W inverter from coupling to the amplifier stage? I'm heavily filtering every section of the power supply and using ample grid stoppers as RC filters, but the faint high pitch hum of the inverte remains. Is physically isolating them in seperate chasis necesary?
Old 26th June 2021, 03:09 PM   #129
kodabmx's Avatar
I've not encountered that issue with the 150W supply. Perhaps a small common mode choke on the output would help? They are supposed to switch at 37kHz (if you got the one I think you're talking about) so you shouldn't hear it even if it was leaking through. There is an AC output version that switches at 20kHz.
If you look up how to use the SG3525 chip, you can modify the frequency if you need to.
Old 5th July 2021, 11:24 PM   #130
I figured out that if you install a snubber in the empty spot in front of the mosfet switchers the ringing will be minimized.
Thanks for the great idea, it works perfect now!
Kanged switching power supply for a tube amp.Hide this!Advertise here!
Thread Tools
Switching Mode Power Supply For Tube Amplifier siliconray Siliconray Online Electronics Store 19 10th December 2020 10:05 PM
Reasonable ripple value for the tube amp switching power supply noyan Power Supplies 2 24th January 2020 12:49 PM
High power adjustable switching power supply (SMPS) 3-60V 40A Richiewillmott Power Supplies 12 1st December 2019 01:47 PM
Switching power supply for tube filaments possible??? noyan Tubes / Valves 59 20th November 2017 08:35 PM
Switching power supply for tube-pre JasonLee Tubes / Valves 12 20th March 2007 12:26 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
