Ganged switching power supply for a tube amp.
Old 1st April 2020, 12:08 AM   #51
kodabmx is offline kodabmx  Canada
Spreading triode love.
kodabmx's Avatar
This one in particular is marginal. I've used it for a phono stage with success before, but I feel 160mA@150V might be pushing it for this supply. It was struggling with 25mA@330V...
If you can't learn to do something well, learn how to enjoy doing it poorly.
Old 1st April 2020, 11:05 AM   #52
indaco is offline indaco
By the way, I found in your country this one:
Quiet Power Supply for Tube Amp - Tube Amp Kits by London Power
Although not so cheap, it would seemed to be SMPS...but I'm not sure.
Old 2nd April 2020, 03:31 AM   #53
PRR is offline PRR  United States
PRR's Avatar
Keep clicking the options.
It is a plain old linear supply with 50/60Hz transformer.
The transistors on fins are for Kevin's variable-voltage scheme to make big guitar amps distort at less loud level.
Old 2nd April 2020, 10:58 AM   #54
Yes, I realized then it by a better reading...with the TX furnished, the big caps and mosfets it could be only that.
Old 16th April 2020, 01:34 PM   #55
moapys is offline moapys  United States
...@PRR - Might you have a link for both the board/tranny above, as well as the referenced "Kevin's variable-voltage...guitar-amp...distort at lower level" comment?
Thanks very much!
Old 17th April 2020, 12:10 AM   #56
PRR's Avatar
There's no direct link; different options give different choices and images. Keep clicking the options!
There's also technical papers on the site carefully explaining Kevin's techniques.
Old 17th April 2020, 04:26 PM   #57
Ah; Kevin ...at LondonPower.com - - got it / great site: THX!
Old 14th May 2020, 10:53 PM   #58
kodabmx's Avatar
Just an FYI for those who are interested...
If you use this, you can use the 18V winding to boost or buck for more voltage choices.
500W 12VDC transfer 18VAC & 0-220v-380v inverter module | eBay
Yesterday, using the 160V winding into a doubler, and using an ATX supply that can sag, I was getting 277V out. Today I configured it to boost by 18V and I now have 313V just like I should.
For every 1V difference in input voltage, the output of 380V (full winding) changes by ~32V
In addition to the 160 220 and 380 volt outputs it comes with, you also get 142 172 202 238 362 and 398 volts, too (depending on if you boost or buck) and that doesn't count using a doubler.
Also, the one I measured today runs at 21.8 kHz if anyone cares.
Koda
Ganged switching power supply for a tube amp.Hide this!Advertise here!
Switching power supply for tube filaments possible??? noyan Tubes / Valves 59 20th November 2017 08:35 PM
Switching Mode Power Supply For Tube Amplifier siliconray Siliconray Online Electronics Store 18 16th February 2015 09:59 AM
switching power supply Triviumfan4 Equipment & Tools 1 14th July 2014 12:43 PM
Switching power supply for tube-pre JasonLee Tubes / Valves 12 20th March 2007 12:26 AM
Switching power supply Thomas B Pass Labs 15 9th December 2002 10:28 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
