question about power adapter replacement for batteries
Hello group -
I've put together a little Vellman microphone kit that uses three AA batteries - 4.5V
I'd like to use the device as a one way intercom and power the device off a small power adapter -
The power adapter I have is 5V - 0.7A --
would this power adapter be too high for this small kit? If so - is there a way I could lower the voltage?
Thanks!
Ted
Moderator
Joined 2011
The power adapter I have is 5V - 0.7A --would this power adapter be too high for this small kit?
Do you have a schematic of the preamp? A 5VDC supply would almost certainly be fine,
but some of these supplies put out even more voltage than spec, so check its output voltage
without a load using a DVM first. The op amp used could be a 5V single supply type, some of
which are limited to 5.5VDC maximum.
