Quasimodo results (ONLY)
Old 17th October 2017, 02:59 AM   #11
KevinHeem is offline KevinHeem  United States
KevinHeem's Avatar
This chart shows my results testing an Antek AS-4218 with Cx=10nf Cs=150nf and Rs=6-10Ω. I'm using 7Ω in my actual circuit.
10to6ohm.pdf
Old 19th October 2017, 12:46 PM   #12
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
A mention of the primary configuration might also be useful. From what I remember from Mark's article, the optimal point differs a bit if the primary is wired in series (230VAC) or in parallel (110VAC)
Too many projects... so little time...
Old 26th January 2019, 07:45 PM   #13
andrensairr is offline andrensairr  Australia
Harbuch Electronics I2225FAM (500VA, 240V primary, dual 45V secondaries)
Cx 10nF
Cs 150nF
Rs 19.8Ω
Old 29th January 2019, 04:29 PM   #14
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
Selectronic R-Core (120VA, 240V primary, dual 18V secondaries)
Cx 10nF
Cs 150nF
Rs 110Ω
Old 2nd February 2019, 01:17 PM   #15
Johnny Canuck is offline Johnny Canuck  Canada
Primrose Audio Toroids (two) (508VA, dual 120V primaries, dual 18V secondaries)
Cx 10nF
Cs 150nF
Rs 10Ω
Old 9th February 2019, 06:08 PM   #16
SyncTronX is offline SyncTronX  United States
SyncTronX's Avatar
Antek AS-4218, 400VA, dual 18V secondaries, dual full wave bridges:
(Attributed to another DIYer who requested to not use his name.)
Cx = 3.3nf
Cs = 470nf
Rs = 16.9 ohms
-- Sync
Old 9th February 2019, 06:38 PM   #17
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Posted 08 December 2018 HERE
_
Quasimodo results (ONLY)-jsjsjsjsjsj-png
_
Old 8th April 2019, 11:00 AM   #18
audiomusica is offline audiomusica  Germany
Talema 2x115V, 2x7V, 2x12,5VA
Primaries in series for 230V operation and shorted (for snubbing)
Secondaries in parallel
Cs=150nF, Cx=10nF -> fosc ~ 625kHz(!)
Snubbing this small print torodial transformer I get values for Rs ~ 12Ohm.
Are such low values for Rs reasonable?
Old 8th April 2019, 11:45 AM   #19
kamis is offline kamis  Serbia
Results with Cheapo Modo , ANG low profile 2x30V, 24VA, fosc 10.5KHz .
Very high 24mH inductance. Standard C values, RS 770 Ohm.
Old 8th April 2019, 01:07 PM   #20
Audiomusica, since you doubt your experimental results from No-Math Quasimodo, you have no other choice than to use math for verification.
Your numerical values of fosc (6.25E+5) and Cx (1.0E-8) indicate that the secondary self inductance L is about (6.5E-6) Henrys. We calculate L using the LC resonance equation.
The LC resonance equation: 2 * Pi * fosc = 1 / sqrt(L * C)
Plugging this value for L into equation (A.11) of the Quasimodo design note, we find
R < 12.7 ohms
Which seems to be in broad agreement with your experimental results. You were wrong to doubt them.
Quasimodo results (ONLY)Hide this!Advertise here!
GB for Quasimodo Boards for Planet10 Nikon1975 Group Buys 162 27th February 2019 01:10 PM
WTB: Quasimodo Test Jig Clelow Swap Meet 1 28th November 2016 02:02 AM
Quasimodo parts Quote nuryev Parts 0 19th October 2016 06:24 AM
WTBBB a Quasimodo Test Jig dantwomey Power Supplies 3 6th April 2016 07:03 PM
FS Quasimodo board and parts drpro Swap Meet 2 1st March 2014 02:34 PM
Copyright ©1999-2019 diyAudio
