About Chinese LLC SMPS
Old 20th September 2019, 06:57 AM   #41
hansueli is offline hansueli  Switzerland
What could be the power of this power supply?
It has active PCF
File Type: jpeg WhatsApp Image 2019-09-20 at 08.54.21(1).jpeg (366.3 KB, 161 views)
File Type: jpeg WhatsApp Image 2019-09-20 at 08.54.21.jpeg (295.2 KB, 159 views)
Old 23rd September 2019, 09:58 AM   #42
kees52 is offline kees52  Netherlands
Originally Posted by nigelwright7557 View Post
They have to cut corners somewhere to get the price down.
LLC SMPS are very good. As the transformer primary sees a sine wave and not a square wave there is much less radiation from the SMPS.
The resonant frequency is very important. If you move it by changing caps then you can shift the frequency into the capacitive high current mode and possibly destroy it.
I have the problem with simulating such a smps, not because I can not design it but the transformer who is from a pc supply I have calulated with ExcellentIT7300 looks like the voltages are way higher on the calculated coil values, I had 15 volts 15 amps, 300 volts 250 volts 250mA and 2 x 120 volts 250mA it is for a tube preamp to test the circlotron.
Maybe I did something wrong, it is a ETD 39/20/13 core, I have test all materials but did not change much, why is this? or has this core a gap? the pc supply was half bridge, I have used half bridge, for simplicity when making transformer.
I have simulate al kinds of freguencies, none did give satisfied results, always to high voltages, Maybe ringing on the rectifier I did used a full wave 4 diodes rectifier to spare to much windings.
thanks for eventual giving tips.
regards
Old 24th September 2019, 10:03 AM   #43
Rallyfinnen is online now Rallyfinnen  Sweden
Originally Posted by Piersma View Post
If you want to tune the outputvoltage, adjust R66. It is on the bottomside of the main PCB. My China SMPS measured an max. outputpower near 400W.
For what PS is this?
I have been looking at this one, and it looks similar to the one discussed here:
500W Dual voltage LLC Switching power supply board for power amp PSU DIY | eBay
The voltage should be specified at order, but I would like the possibility to adjust voltage, so this is interesting info for me.
Old 24th September 2019, 11:16 AM   #44
Piersma is offline Piersma  Netherlands
Piersma's Avatar
Default LLC smps
The chinese LLC you mention, is the one i am referring to.
Old 24th September 2019, 03:10 PM   #45
Ok, thank you! What is your opinion about it, is it ok?
Old 15th October 2019, 03:12 PM   #46
the 500w china power supply is not bad but unter heavy load its thermal shuttdown due overheat of heatsink. Maybe a fan could help.
I think the moste heat comes from the rectifing diods. If the where doubled it would be much better. I hope I can sell my china PSU. I don't need it anymore.
My new 36V power supply has same L6599 but much more power and bigger transformer and double the rectifing diods. So less heat is generated.
File Type: jpeg WhatsApp Image 2019-10-15 at 16.50.13(3).jpeg (342.1 KB, 50 views)
About Chinese LLC SMPSHide this!Advertise here!
Hypex Smps 400/180 vs Connex Smps 300Re sumotan Power Supplies 0 4th March 2017 08:09 AM
Hello from China wolver Introductions 4 17th February 2017 08:45 PM
Hi from China miragem3i Introductions 3 2nd May 2013 04:34 AM
Greetings from China hifisupermarket Introductions 4 20th August 2012 03:10 AM
Copyright ©1999-2019 diyAudio
