Another option for an inductor input filter?
Old 1st June 2017, 07:53 PM   #1
Kay Pirinha is online now Kay Pirinha  Germany
Kay Pirinha's Avatar
Default Another option for an inductor input filter?
sometime it is adviceable to prefer a LC power supply filter over a CLC one, i.e. an inductor as the first filter element. Given a two way rectifier with a vacuum or a gas filled double diode with direct heating. Usually the first filter element is connected to the center tapped heater winding. Is it a good idea to connect a center tapped choke in parallel with the heater winding and connecting the first filter cap to it's tapping, so that this choke works as the L input? By this way, I think, a gapped core is no more necessary, so the needed inductivity could be achieved by less turns.
Or is it better to use a bifilarly wound choke with a gapped core for this duty?
Best regards!
Old 1st June 2017, 08:10 PM   #2
DF96 is online now DF96  England
You would need the AC and DC to go in opposite directions to make use of a common-mode choke. In a PSU smoothing application they go the same way. No free lunches!
Old 5th June 2017, 08:34 AM   #3
Happy 2017 is offline Happy 2017
So, which inductor will be use for this design?considering the AC-DC opposite directions?
Old 5th June 2017, 02:24 PM   #4
Ketje is offline Ketje  Belgium
Ketje's Avatar
AC goes in two directions, how do you see "opposite" ?
Mona
Old 5th June 2017, 03:37 PM   #5
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Choque input filter is my prefered, but in your case you will need a large choque capable of carrying heater current (Several amperes) with negligible DC loss, but with sufficiently high inductance to provide choque input action. So it will be very large, bulky and expensive, although it can run.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Another option for an inductor input filter?Hide this!Advertise here!
output filter inductor design toyer Power Supplies 7 13th May 2014 04:05 PM
Output Filter Inductor mike49504 Car Audio 3 10th February 2012 07:48 AM
TDA8924 filter inductor ghabrius Class D 8 24th April 2011 10:04 PM
Notch filter inductor question IG81 Multi-Way 2 11th November 2010 07:23 PM
SI 5066 Input Cap Option Panelhead Class D 10 24th June 2005 06:15 AM
Copyright ©1999-2019 diyAudio
