PSUD (Power Supply Unit Designer)
Thread Tools
Old 29th June 2019, 09:23 AM   #91
DF96 is offline DF96  England
R.I.P.
Originally Posted by eduard
Because usually you will see people adding a small bypass capacitor on a big power supply capacitor. Sometimes adding a low esr capacitor at the output of a regulator can have bad effects. Could something similar happen to a simple power supply? And that is the reason why would use an RC instead of only a capacitor.
A snubber is not a bypass. Most bypass caps do nothing useful; some do harm; a few do some good.
The idea of the snubber is to damp the LC resonance formed by the choke and the capacitors, if necessary. It has some similarity to the problem at the output of a regulator, because there you have a virtual inductor (the regulator output impedance) so a capacitor (which people love to add) can resonate.
In my audio documents i have an article written by Morgan Jones where he has done some test with snubbers or just caps positioned across the secondary windings on or across the diodes. HIS conclusion in most cases a 1 nF cap in series with a 1000 ohm resister across the transformers secundary is all you need.
Different snubber in a different position for a different purpose.
Old 6th October 2019, 04:36 PM   #92
R Kneck is offline R Kneck  United States
First, many thanks to duncanamps for this invaluable tool.
I have a question about entering values for a center tapped full wave rectifier.
For entering off load voltage, the help file is quite clear that you should enter one half of the total end to end voltage.
I am unclear about the impedance for the transformer secondary.
Bringing up the source impedance calculator help file states that "Winding resistance: The measured resistance of the secondary winding." Would this be the resistance from the center tap to one end just like the off load voltage or the resistance across the entire secondary?
Again, this is a great resource for the diy community!
Old 6th October 2019, 04:53 PM   #93
trobbins is offline trobbins  Australia
trobbins's Avatar
yes
Old 6th October 2019, 04:57 PM   #94
Should I measure the resistance
a) from the center tap to either end
b) across the entire secondary winding
Old 6th October 2019, 05:07 PM   #95
RickRay is offline RickRay  United States
Any movement on the 3rd version. I struggle with trying to model rectifiers not listed. The rectifier modeling feature would be a godsend.
Old 6th October 2019, 05:49 PM   #96
duncanamps is offline duncanamps  United Kingdom
Take the impedance from the centre to one leg. In reality, your transformer is likely to be wound with two different winding resistances as the one towards the outside uses more copper for the same turns. Take the end to end and divide by 2 if you really want to get a good result.
The help file offers no guidance on that, an omission that will be fixed in PSUD 3.
Old 6th October 2019, 05:54 PM   #97
Yes, things are happening, just very slowly. It's a whole ground up rewrite, the simulation engine is complete and is extremely accurate, unlike PSUD2.
The user interface is being sorted out at the moment, and I continue to spend time here and there when other demands permit. It's not likely I will get anything out on the streets until the Christmas break, but that's the one time of the year when I get an opportunity to do stuff like this
Old 6th October 2019, 08:22 PM   #98
PRR is offline PRR  United States
PRR's Avatar
Thank you very much. I turn to PSUD almost daily.
Old 6th October 2019, 08:37 PM   #99
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
Indeed. A great tool. Thanks for your efforts.
Old 7th October 2019, 10:14 AM   #100
merlin el mago is offline merlin el mago  Catalonia
merlin el mago's Avatar
Your effort is really appreciated.
PSUD (Power Supply Unit Designer)Hide this!Advertise here!
Thread Tools
Timestep Power Supply Unit dbx01 Swap Meet 4 3rd April 2015 06:51 PM
FS: APC Power Supply Unit timothycn Swap Meet 0 19th March 2012 06:01 AM
is there a power supply unit for prototyping? miguel567_98 Tubes / Valves 9 7th January 2010 12:49 PM
Building a power supply unit. S.C Chip Amps 4 6th August 2003 08:59 PM
Power supply unit question Ilianh Pass Labs 22 28th October 2002 08:27 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
