Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#431 |
I really like my nirvana power supply, purchased from Chicago electric - prompt shipping and communications. It seams like a nicely built unit and good value for the money but for the life of me I do not understand why the dropped the ball on the last mile- the output cable. When all things settle down And warranty is not a problem I will have to replace it. At some point I will have buy a shanty and give it a try as well. I will also have to buy and build a Iancanaca power supply with his super cap board. I bet when all is said the shanty will be cheaper, but it will be nice to compare them.
Bill |
#432 |
I found that the output cable was better than using the USB connection with the usb to barrel connector that came with the DAC, so cables can make a difference depending on shielding/grounding schemes and how close DC cable is to AC cables. Star quad would be optimum DC cable, but that adds $$. Question for Allo is the connect ground to PE switch operational for the USB connector?
#433 |
Hi Chris
yes it is. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
300B 5V DC filament supply from 5V AC windings | cowneko | Tubes / Valves | 20 | 29th November 2016 03:32 PM |
Float charger? Cut off at 13.5v rest until 12.5v before switch on? | danielwritesbac | Power Supplies | 108 | 18th August 2015 07:26 PM |
Need reference design of a 5V 80W to 100W DC SMPS | roomi | Power Supplies | 2 | 9th November 2014 10:44 AM |
5v SMPS for headphone amp | insta | Headphone Systems | 6 | 24th April 2009 04:30 PM |
Can you make 0-5V DC out of 2.5-0-2.5V AC | Ralph | Tubes / Valves | 17 | 23rd September 2003 04:20 PM |
New To Site? | Need Help? |
