Power Supply for Starving Student hybrid?
Old 24th January 2017, 07:34 PM   #1
Cata1yst is offline Cata1yst
Default Power Supply for Starving Student hybrid?
Hi.
So im trying to build a clean 48v psu for the starving student hybird. Mostly people use a POE injector psu, but theres been a few cases of the floating ground building up charge and frying a DAC. cisco power supply, grounding and the Millett starving student
Since im not a student any longer I'd like to start with a solid foundation providing power and make small improvements here and there to the amp.
Could use any resources to guide me in building a 48v psu. I have a basic undergrad grasp on full bridge rectifiers, bjts, etc, but have never built anything from scratch. I wouldnt mind going with something thats been designed before, but from what I've seen not too many popular diy designs ("the wire", sigma 11) push up to 48v (granted those are meant for ss applications)
Old 28th January 2017, 09:31 AM   #2
R.I.P.
A 35Vac transforer will get you pretty close to 48Vdc. Probably around 50Vdc to 51Vdc.
Do you need precisely 48Vdc? what tolerance is permitted?
Do you need single polarity supply, or dual polarity supply?
regards Andrew T.
Old 1st February 2017, 06:28 PM   #3
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
This guy, right?
http://www.pmillett.com/starving.htm
I would be inclined to use a toroidal transformer from Antek, and a Maida (LM317 based) regulator.
$11, assuming you are in the US...
AN-0240 - 25VA 40V Transformer - AnTek Products Corp
Parallel the dual 40v windings for 600mA before rectification, should give enough headroom for a basic linear regulator to sit you where you want. Cheap too.
Here's a couple Maida style regs that would work well, just use a BIG heatsink and you should be fine... Of course you will need to change some resistor values to be able to set your output at 48V.
Old 1st February 2017, 08:11 PM   #4
R.I.P.
looks like you need +48Vdc and -19Vdc.
regards Andrew T.
Old 1st February 2017, 08:23 PM   #5
Lingwendil's Avatar
The 19v is across the filament of the tubes, and the filament is being used as a load resistor for the Mosfet source follower consequentially feeding the filament to heat the tube. This is a single supply design.
Old 1st February 2017, 08:52 PM   #6
Ketje is offline Ketje  Belgium
Ketje's Avatar
Before you blow-up the LM317,beware.The crossing at the 200Ω is a connection, point is missing !
Mona
Power Supply for Starving Student hybrid?Hide this!Advertise here!
DAC and starving student millet hybrid combined in one Rinna Digital Line Level 6 7th June 2015 09:12 AM
cisco power supply, grounding and the Millett starving student crispchicken Headphone Systems 5 7th February 2014 05:38 PM
cisco power supply, grounding and the Millett starving student crispchicken Headphone Systems 1 18th December 2013 06:18 AM
Millett Hybrid Starving Student (12AU7) vixr Headphone Systems 6 12th October 2013 08:31 AM
