bridge rectifier
bridge rectifier
bridge rectifier Please consider donating to help us continue to serve you.
Old 14th January 2017, 03:01 PM   #1
rock12 is offline rock12  United States
Default bridge rectifier
the input to my bridge on both sides is 26volts. the output side is -12volts and +54 volts. I replaced this part and got the same result. where else should I check?
Old 14th January 2017, 03:12 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
The ground connection may be floating. The centre tap of the transformer forms the centre voltage between the two smoothing capacitors and must be connected to the centre point.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 14th January 2017, 03:56 PM   #3
this power supply/amplifier(for the pluto 2) was working. It fried the tweeter speaker on this power supply side. when I check the center tap I get readings in low milli volts and some DC readings at speaker output
Old 15th January 2017, 09:31 PM   #4
DF96 is offline DF96  England
Show us exactly what you did. As he says, sounds like the CT is disconnected.
Old 15th January 2017, 10:06 PM   #5
turk 182 is offline turk 182  Canada
i'd check the filter caps if the bridge blew did the caps survive?
and if your getting DC at the output you still have not resolved the problems that took the rectifier out in the first place.
hope you have a "Dim bulb tester" and are using it to get the readings your reporting!
bridge rectifierHide this!Advertise here!
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 09:26 PM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 03:43 PM
Bridge Rectifier thylantyr Solid State 2 21st August 2003 10:11 PM
Copyright ©1999-2019 diyAudio
