Best capacitors for power supplies update
Best capacitors for power supplies update Please consider donating to help us continue to serve you.
Old 22nd November 2019, 07:24 PM   #121
carlmart is offline carlmart  Brazil
AFAIK the question in charging the capacitor is to elevate voltage little by little, not current.
A series resistor might be a good idea too, to limit current.
Old 22nd November 2019, 08:18 PM   #122
sdaudio2 is offline sdaudio2  Canada
Thats what I said in the other thread...the cap looks almost like a short upon initial application of voltage ...there is a problem with the cap if the current drawn doesn't start to drop back within a certain time...usually indicates leakage ohterwise...
Old 24th November 2019, 11:40 AM   #123
Once I read that the way to reformat the cap was to raise the voltage up to half the cap's voltage capacity, leave it there for some time (don't remember how long) and then continue up to the voltage you are going to use. Do you agree?
Best capacitors for power supplies updateHide this!Advertise here!
Power Amp's NP capacitors and BP capacitors confuse ?? shehantha Solid State 11 2nd July 2016 12:41 PM
Choke power supplies for Class AB Power Amplifiers - which Rules for Calculating ?? tiefbassuebertr Solid State 12 3rd November 2011 09:47 AM
ATX (computer) power supplies for power amp robmonk Solid State 29 12th February 2005 06:06 AM
High voltage metal can oil capacitors for tube amp power supplies CCOZGO40 Swap Meet 1 3rd November 2002 09:10 PM
Regulated Power Supplies for Low Power Amps PTL60 Solid State 18 6th February 2002 07:24 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
