Juma's Easy-Peasy Capacitance Multiplier
Old 15th November 2018, 01:35 PM   #631
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Be sure to check the emitters of T1 and T2 with an oscilloscope, looking for unwanted excess ripple when delivering the maximum permitted output current. This circuit's behavior gets worse and worse as you increase the output current, so: check it and double check it at MAX current.
You may need to adjust the values of R2 and R6 to find a compromise between (A: total voltage drop from in to out) and (B: ripple), that you can accept. Post #35 says more about this.
R2 = infinity gives the least ripple and the largest (total voltage drop from in to out)
R2 = zero gives the most ripple and the smallest (total voltage drop from in to out)
Old 16th November 2018, 06:04 AM   #632
prasi is offline prasi  India
prasi's Avatar
Thank you Mark for your suggestions.
As per the Juma's schematic , the values are 12k Ohm for the R2 and R6.
Also requires a regulated input for the circuit , so the on-board rectifiers + CRC may not be such a good idea.
Prasi
My revamped site https://sites.google.com/site/analogdesign1234/
Old 16th November 2018, 07:07 PM   #633
prasi's Avatar
Would this work well with a regulator up front... may need some thinking on cap values and voltages. bloody symmetrical and no jumpers...
Juma's Easy-Peasy Capacitance MultiplierHide this!Advertise here!
My experience with a Capacitance Multiplier Shoog Pass Labs 29 5th September 2010 07:02 PM
Capacitance Multiplier PSU Ted205 Chip Amps 3 2nd March 2009 02:27 PM
Capacitance Multiplier Kinnja Solid State 2 13th January 2008 09:12 PM
