it is, there are many ways to do it, but its not going to be very efficient...you can have 12 volt DC convert to 120 volt AC, and then you use proper transformer to create +/- 12 volt DC...
converters...
https://www.walmart.com/c/kp/12v-power-inverter
second option is DC to DC converter...
https://www.automationdirect.com/ad...C_Converters?gclid=CJr8ldm1kc8CFUpahgodWLAGWw
third option is to use another battery...
converters...
Use a DC to negative DC converter
like this
12V Negative Voltage Daul Power Supply LM2596 12V to ±12V DC Converter 3A | eBay
Lol no please.
like this
Lol no please.
YJ sell this 12V (but i also know that 4S li-ion batt at 16.8V is within its range/under its maxV ) DC BOOST but its for 45v +/- https://www.yuan-jing.com/Voltage-Converter/12v-to-45v-dc-to-dc-converter-500w I would also like to know if there something that will reduce the 45V +/-DC voltage to 12 or 15v +/-DC for +/-DC pre-amp boards.
The IC ICL7660 or 7662 can convert a positive supply into a negative, but at low power. It is used extensively in industrial environments and very easy to use, only 2 capacitors needed.
And don't forget to place output filter
https://www.intersil.com/content/dam/Intersil/documents/icl7/icl7662.pdf
Simplest, impossible.
"And don't forget to place output filter"
May or may not be necessary, for op amps with good PSRR, is not mandatory. Use good tantalum caps only, and short traces in your PCB.
wwenze:
This looks ideal to my needs.
easp:
Well, I am assessing various components for my next portable boom box. Some of the pre-amps and power amps require dual rail power. Not being familiar with how that works I am just looking to learn.
What concerns should I have about driving a power amp?
-James
easp:
-James
If you need to feed a power amp which needs +/- 12V rails at a couple amperes, you may build a power inverter ... and in that case why limit yourself to +/- 12V? you may choose way higher rails which will let you use practically any power amp you wish.
That´s what car amps do, they often go from, say, +/-25V to hairy +/- 70V .
- Power Supplies
- -12v +12v from same power source?
