18650 battery pack
18650 battery pack
18650 battery pack Please consider donating to help us continue to serve you.
Old 15th April 2016, 07:21 AM   #1
Camerong is offline Camerong  New Zealand
Default 18650 battery pack
Hey everyone.
What do you guys think of building your own 18650 battery packs? Or is it better to just buy one with included bms and charger to suit..
I was thinking something like this
22.2V 25.2V 6*18650 2600mAh 6S Lithium ion Li-ion Battery Pack [6x 18650 6S 22V 2600mAh] - $38.20 : Lithium Rechargeable Batteries, Battery BMS, Pack Assembling
Li-ion Li-Po 25.2V 22.2V 2A 6S Wall Socket Battery Charger AC DC [25.2V 2A Lithium Battery Charger] - $17.20 : Lithium Rechargeable Batteries, Battery BMS, Pack Assembling
But it seems a lot cheaper to rip a laptop battery apart and wire 6 batteries in series and put a bms on it. Or is it not as simple as that?
I want to have a switch switching from the battery pack to 240 ac.
Can someone please send me an idea
Old 16th April 2016, 12:58 AM   #2
Foxx510 is offline Foxx510  Australia
I don't see a problem with using laptop cells if that is cheaper. You do need to know what you are doing though with these - they don't respond well if mistreated as you are probably aware. Just don't try to solder to them - only use tabs or spot welding. Which bms are you considering? What is the load?
Old 16th April 2016, 01:14 AM   #3
Haven't decided in a bms yet can you recommend one?
Here's the load
Sure Electronics AA-AB32174 2x50W TDA7492 Class-D Amplifier Board
Or
http://home.teletu.it/APPSI/APP%20SI...0DATASHEET.pdf
Old 16th April 2016, 03:10 AM   #4
Bare is offline Bare  Canada
IF you want Battery power ??
Either Use Lead Acid cells (moto batteries are smallish/inexpensive)
OR Nicad cells which have tested as being Extremely 'clean' (best) battery power sources.
Bit of a chase to find these days.. but still doable.
Old 16th April 2016, 05:13 AM   #5
Something like this? 22 2V PCM Protection Circuit Module for 6S Li ion Li Po Battery CURRENT10A SM519 | eBay
Old 16th April 2016, 10:09 AM   #6
Yeah I was thinking nicad but it's heavy and has memory loss after a while. It's going to be a portable speaker box and I would prefer it to be as light as possible.
Even if it cost me a bit more.
Just wondering how I could have one cord and be able to charge the battery and run it off the same cord for 240v ac.
Old 16th April 2016, 11:14 AM   #7
R.I.P.
I just bought a 22Ahr 3.7V battery pack. It weighs 462g
It has it's own built in charging system, so hopefully the USB 5V never damages it.
It also has a set of USB 5V outputs.
Use that into a DC to DC converter and you are go.
Building you own lithium battery charger is not easy.
regards Andrew T.
Old 16th April 2016, 11:46 AM   #8
You'd need to limit the charge current to the cells(and the voltage, obviously) if you used the same plugpack to charge the cells and run the device. You don't want to be charging your cells at 5 amps or whatever the plugpack you use is. 1 amp would be about right.
Charging single lithiums is simple CC/CV charging. The trick managing your cell balance, over discharge etc. You need a decent bms for that.
Old 16th April 2016, 09:55 PM   #9
Ah ok right.
So I will would be much better off having two separate
Plugs one for running the device and one for charging.
I'm not too worried about that.
Just would have been convenient.
Also is the bms the only circuit that I will need on the safety side on charging?
Old 16th April 2016, 09:58 PM   #10
Where did you purchase this Andrew?
18650 battery packHide this!Advertise here!
Attaching a battery pack to a chassis? rif Construction Tips 5 7th September 2015 04:54 AM
Battery Pack Burnout scwhiteley Power Supplies 4 2nd April 2010 01:01 AM
Battery Charger for 15V Li-ION Battery Pack ??? Jan Dupont Parts 2 11th April 2009 03:18 PM
18650 battery holder? MikeHunt79 Parts 1 4th February 2009 01:30 PM
Battery pack as PS? evilentity Power Supplies 4 14th May 2005 08:48 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
