I post this
If one adopts polypropylene will it still behave as a snubber?
Then you ask this............................You need a snubber to damp the circuit and minimise the ringing.
A snubber is a resistor to absorb energy (and generates heat) when current passes across it.
ESR is equivalent series RESISTANCE..................................Should one avoid very low ESR dielectics like polypropylene?...............
The 7V 15VA transformer is good for this project no need to buy another one. 6V might be slightly more optimal, less power dissipation on the regulator yet table operation but probably not worth the money/effort.
Hi and thanks again.
No way to find a 7V or 8V EI transformer ... no way. Values jump from 6 to 9.
It seems that 6 and 9 are more standard value.
Ok ... just caps and maybe some mains filters.
Regards, gino
Hi and excuse me if i reply to myself ...
but i have got an important confirmation from some experimenters that a toroidal placed very close to the digital chips is very very bad.
So the idea of an external PS with umbilical DC cable to the unit is not insane, actually the contrary.
In this way the transformer, that has always some EMI leakage, will be shielded.
I wonder if an aluminum box is a good shield ... do not think so but i am not sure.
Is steel better ?
Thanks a lot again, gino
Is steel better ?
Stray field from that 7V 15VA can't be very high.
Hi ! there are some people modifying the same unit in order to ger better performance. One has placed some this around the transformer
AB-5100 X 8.26" 3M | 3M5100D-ND | DigiKey
and he says there are improvements in sound.
I still would prefer the only source of "possible" EMI out of the small box with circuits ... ok there will be another box but still ...
I will do that for sure. I could also buy some of the 3M sheets and place them on the panels of the circuits box.If you want external box one tip is to get a cheap aluminium box from ebay or aliexpress
I will post some pics as soon as i will receive the pieces ...
The tape is not very good emi protection. Distance is what is needed if it affects the circuit, extra box even better. Here is a cheap one, but not very pretty
1pc Retex Box Aluminium Enclosure Minibox RM 14 125x60x205mm 31040014 | eBay
Hi and thanks a lot again.
This confirms my sensation ... those guys are good but low in tech education.
I had this feeling. EMI and maybe even more RFI are disastrous for digital.
thanks a lot for the very helpful advice.
I have to wait for all the pieces i bought to see the needed size for the box.
As i said i still would like to reach the box with a DC umbilical, even not regulated and leave the regulation duty to the regulator on board.
But i have also bought this one ... i do not know if i did right
http://www.ebay.com/itm/371189087840?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
i have been intrigued by the promise of
I do not know if it is just marketing or what.Output Noise: < 40uV RMS (10Hz to 100kHz)
Thanks again, gino
Since you bought it the best way to find out is try it
If the components are original and good quality you got a decent regulator, easy to adjust via trimpot. There's a lot of fake components/sketchy PCB layouts on ebay, don't know anything about this seller but watch out... LT1963 has low dropout so the 7V transformer will still be good, 6V out it enough..
I doubt that it will shorten the lifespan of the transformer, haven't seen anything to the contrary but can't say 100%.. Why not parallel connect the secondaries? .. The 7V 15VA has plenty power for this application no need for anything larger.
Hi ... because i am worried to exchange the + and - of the two secondary
Here the transformer has two primary windings and two secondary windings, four in total. The connections to the primary or secondary windings must be made correctly with dual voltage transformers. If connected improperly, it is possible to create a dead short that will usually destroy the transformer when it is energized.
This is enough for me to try with just one secondary connected and the other left open/unused
and see what happens
Looking at the secondaries if their terminals are not market + and - what would happen if i connect the + of one secondary with the - of the other and the same for the other terminals ?
Instead using just one secondary i will not have the least problem for connection.
I have never understood the phase issue ... never.
Regards, gino
Because this is quite clear
but what i have to do if the terminals are not marked + and - ?
How can i identify them ? this is the problem ... always.
Thanks again, gino
Thanks again, gino
The +/- labels are a bit missleading since it's AC. Is it any label on the transformer indicating the "phase dots" to pin number? If not, what brand and model search for datasheet.
Hi ! bought another one little but very nice ... and with terminal marked and very good datasheet. These people are serious !
Chassis Transformer 20VA 7.5V+7.5V
http://www.ebay.co.uk/itm/291216912314
http://www.spiratronics.com/data/4430.pdf
this is exactly how i like it.
EI type with primary and secondaries separated for a good HF mains noise blocking
I do not know why but in lab grade power supplies i have always seen EI type, in some cases exceptional (i remember a HP power supply with a huge EI. Beautiful)
now i have to stop a little and wait for the pieces.
Thanks a lot again.
Kind regards, gino
Check for a label on the transformer, the + in the picture is labeled as a small dot on the transformer. If there are no labels on the transformer search for brand name and model name on the transformer, then google for datasheet that might provide phasing dots to pin number. Please post pictures of the transformers
Hi and thanks a lot again for the very kind support.
On the basis of your advice i have decided to buy from now on only branded parts and with datasheets.
As i said above i have bought another one from what appears to be a very serious UK manufacturer and terminals should be clearly marked.
I should not miss them.
I am obsessed by transformers and capacitors above any other component.
It is where the energy is transformed and stored ... is like the engine in a car.
Often i have had the impression that very good coomercial equipment are held back but substandard power supplies
This is what i will do when retired. To revamp and modify pieces of hifi in the strategic parts.
On principle i think that any cheap commercial design can be modified with some positive improvements. Any.
Thanks a lot again.
Kindest regards, gino
- Power Supplies
- Mains filtering for a digital equipment.
