Reflektor-D builds
Reflektor-D builds
Old 10th March 2019, 05:54 PM   #1501
Greg Stewart is offline Greg Stewart  United States
Reflektor-D builds
Salas,
I have a couple of 'generic digital' power supply bases with 9 rails on each. 4 of these rails are the DAC and digital processing (isolators, reclockers, etc) supplies. On this base, those supplies are based on 2 Hammond 220D16 transformers, with one secondary used per supply. The secondary feeds a diode bridge of DSEP30-06A diodes (overkill, but in my experience good sounding) and the output C of each supply is a Jensen 47000/25V 4-pole capacitor. I also include a John Swenson transformer-ringing suppression snubber on each secondary (more info on that here: Good linear PSU(s) for CAPS music player that won't break the bank - Page 12 - Music Servers - Audiophile Style ).
All of these come together at a 16-pin Hirose connector which allows me to plug and play various digital sources.
Each 'base' also has a supply with a 5V and a 3.3V rail for a source (RaspberryPi, SDCard player, or similar), a lightly-filtered quick-drop-out supply for an on-off mute relay, and an output stage supply with a +-21V output where needed.
For the Allo.com Katana, I use just 2 of the DAC/digital processing rails. Sonics are slightly better if I use one rail from each transformer.
Greg in Mississippi
P.S. These bases are built onto a large bamboo cutting board which also acts as the siting platform for the digital source in use. My other base like this uses some discontinued Amveco toriod transformers instead of the Hammonds. At some point I need to compare sonics between the 2 versions.
Everything matters!
Old 11th March 2019, 01:39 AM   #1502
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Reflektor-D builds
Greg,
Quite elaborate, I was sure it would be an interesting setup description. Thanks for the details.
Old 11th March 2019, 02:49 PM   #1503
sbelyo is offline sbelyo  United States
Finished these two minis a while back. They're powering an Amanero/Chronos/Rhea stack and a BIII pro se (9028)
Old 11th March 2019, 03:12 PM   #1504
Salas's Avatar
Reflektor-D builds
Nice arrangement and thick cables
Old 11th March 2019, 03:57 PM   #1505
Thanks, I used 14 AWG stranded. Any bigger and it was going to be tough getting them in place
Reflektor-D buildsHide this!Advertise here!
GB for Salas Reflektor-D Power Supply for Digital Tea-Bag Group Buys 405 13th March 2019 10:56 PM
NOS Russian Reflektor 6P6S (6V6) tubes were a pleasant surprise KrankKall Tubes / Valves 7 26th February 2014 07:07 PM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
FS 8X 6P3S Reflektor Valves NOS Tbird Swap Meet 9 6th June 2011 03:18 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
Copyright ©1999-2019 diyAudio
