Switched power supplies better sometimes?
Old 3rd January 2014, 07:51 PM   #1
lorienblack is offline lorienblack  United Kingdom
lorienblack's Avatar
Default Switched power supplies better sometimes?
I'm looking to power a T class amp in an active speaker build. There seems to be some consensus that a decent switched power supply is every bit as good as a linear supply for this application.
Have my eye on this item. eBay number - 261364459820
And there seems to be a lack of people who experiment with quality shunt regs for linear power supplies for Tamps - is there a reason for this?
Thanks in advance - LB
Old 3rd January 2014, 11:25 PM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I prefer linear supplies with my amplifiers.
SMPS can be noisy, radiated and conducted.
They are sometimes fussy about a minimum load and can be unstable if lightly loaded,
Not as easy to fix if they die.
2020 versions of PCBCAD51, PCBCAD360 and PCBCAD720 out now >>> https://www.murtonpikesystems.co.uk
Old 3rd January 2014, 11:39 PM   #3
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
One reason could be it seems like a conflicting philosophy. A shunt regulated supply is in effect a class A power supply. Switching amps are the antithesis of class A - their aim is high efficiency.
If a person's concerned about efficiency they'd use a switching amp with an unregulated linear supply or perhaps a switcher. A person using shunt regs would be one trying to get the best SQ - in which case they'd eschew switching amps for not delivering the sonic goods.
In every realm, in every form of human endeavor, the technosphere’s goals appear to be the same: to technicalize the field to the greatest extent possible.. - D. Orlov, Shrinking the Technosphere
Old 4th January 2014, 12:34 AM   #4
R.I.P.
SMPS and T-amps simply go together well, whats to argue about ?
Nobody in their right mind would use shunt regulation for any
sort of power amplifier except for a very purist class A design.
Its a very bad idea in all respects for a T-amp, and most amps.
rgds, sreten.
Old 4th January 2014, 06:38 PM   #5
Jsixis is offline Jsixis  United States
I think it depends on what you have and what you know.
I have quite a few transformers that only have 2 secondary wires and I want to attempt using them for class D.
I keep searching but have yet to find a diagram of a linear power supply for a class D amp.
I've read about 60 of the 100+ pages on this power supply board, I'll let you know if I find one.
I know nothing, so learning is really awesome.
Old 4th January 2014, 08:06 PM   #6
Thanks fellas - I'll go for the switched power supply. I come from building class A amps and DACs where lots of folk rant about linear supply and regulated supply.
I am listening to a Topping TP2020 mk2, regulation switched power supply, and it sounds wonderful as is. Quite simply magic in fact.
Appreciate you thoughts - LB
  Reply to this post
Switched power supplies better sometimes?Hide this!Advertise here!
power but not switched on? redrooster Solid State 0 14th August 2010 01:59 PM
Switched mode power supply MMicke Car Audio 3 19th February 2005 10:42 AM
Switched power supply? Johan_Ch Tubes / Valves 38 31st January 2004 11:53 AM
Switched mode power supplies Magura Parts 13 3rd January 2004 05:44 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
