Power supply bypass capacitor types
Old 14th November 2013, 01:08 PM   #21
KSTR is offline KSTR  Germany
KSTR's Avatar
Originally Posted by fpitas View Post
I've found that with reasonably closely spaced surface mount decoupling caps, if the paralleled values are in the ratio of 10:1 or greater, the resonance between caps is minimal. I didn't invent that, I got it from an old app note somewhere, but it does work in practice.
(bold mine). I think (I know, that is) it's the other way 'round. Don't parallel low ESR caps with more than 10:1 capacitance ratio (assuming increased ESL from the bigger packaged ones).
Only way to really know if you are safe or not when paralleling low ESR caps is either an in-situ network analyser plot or a close look at a bell-ringer time response, in-situ as well. Otherwise stick with a high-ESR tant/'lytic plus a single low-ESR film/ceramic.
Old 14th November 2013, 01:11 PM   #22
fpitas is offline fpitas  United States
The caps I normally use are all quite small, generally 0402 and 0603, 0805 at the largest. I've encountered no problems following the 10:1 rule, and yes it has been examined with an oscilloscope and spectrum analyzer, as I do this sort of thing for a living. It has also been simulated using Genesys. YMMV, and all that.
Francis
Old 14th November 2013, 01:16 PM   #23
KSTR's Avatar
Originally Posted by Monte McGuire View Post
If the larger cap is somewhat lossy, as a tantalum or aluminum electrolytic would be, this resonance is damped.
Yep, the trick is that the inductive slope of the large one is swamped out by the ESR (or additional external R) so that it cannot create a problem at the intersect with the capacitive slope of the smaller cap. Reminds me about opamp compensation, more than 20dB/dec slope difference at Aol 1/beta intersect --> potential problem.
Old 14th November 2013, 01:21 PM   #24
KSTR's Avatar
No doubt here, as with same ballbark inductance the resonances are only apart by a factor of 3 or 4, problems start at 10x++. My comment was more like when people try to bypass one bigger "audio grade" THT film, notably with axial leads, with something too small (both capacitance and ESL).
Old 14th November 2013, 01:28 PM   #25
Ah well; as I said I would never use leaded parts for bypass with high speed devices. It's just asking for trouble.
Francis
Old 14th November 2013, 01:29 PM   #26
KSTR's Avatar
Or just somehing like this, 3u3 + 150n, which is 20:1 and inductance not too far apart, the peak is still benign here at ~0.4R... now assume a big axial 3u3 cap...
Old 20th September 2019, 06:18 AM   #27
goodguys is offline goodguys  United Kingdom
Originally Posted by AndrewT View Post
Tin,
the resistor view is valid.
It;s the resistance that does the snubbing.
Similarly it's the ESR that does the snubbing, if there is the correct amount of it.
So does that mean all the money i have been spending on buying high quality polypropylenes is wasted, that i might as well have stuck to using a high esr al electrolytic all along, potentially better.
If a higher esr cap is better why use ceramics when al electros are more commonly available and in a wider range of values.
Old 20th September 2019, 10:00 AM   #28
DF96 is offline DF96  England
No context means no comment.
However, it is certainly true that some purchases of 'high quality' capacitors for audio use are a waste of money. Some may be worse than that; the 'high quality' capacitor might actually be a worse fit for a particular circuit duty than a perfectly ordinary cheap component. Good engineering is the answer.
Old 20th September 2019, 06:00 PM   #29
Monte McGuire is offline Monte McGuire
Ceramics are smaller and they don't wear out, so for some applications where you don't need large capacitance, a ceramic is a better idea than an electrolytic. Because they are physically smaller, they will also have a higher self resonant frequency, making them a better fit for some types of supply bypassing.
Old 21st September 2019, 04:45 PM   #30
High ESR is better when the circuit calls for high ESR; elsewhere high ESR may be a problem or it may not be a problem.
Power supply bypass capacitor typesHide this!Advertise here!
Power Supply Bypass Cap? patfont Power Supplies 5 17th September 2011 09:50 PM
power supply bypass cap size BigE Power Supplies 11 5th July 2011 02:59 PM
Bypass caps on power supply digital desire Solid State 55 18th January 2007 04:15 PM
Want to bypass power supply, but... beanbag Chip Amps 1 17th November 2005 04:47 PM
Power Supply Bypass Caps dsrviola Solid State 1 3rd November 2002 07:15 PM
Copyright ©1999-2019 diyAudio
