diyAudio Power Supply Circuit Board v3 illustrated build guide
Thread Tools
Old 3rd March 2021, 08:51 PM   #1621
myleftear is online now myleftear  Switzerland
myleftear's Avatar
Indeed, sometimes technical details are more important than mind-comfort. haha.
I have, btw, built my PSU in a similar but simpler way — rectifier & cap bank sitting above the tranny, minimum space (a mere few mm so that they're not touching each-other) and nothing in-between. It's quiet.
And pls do not remind me how many times I dissected the PSU or its alignment in the chassis to try to get them into the symmetric axis, or get the shortest possible wires. (OCD, yeah yeah yeah)
dobedobedo...
Old 4th March 2021, 04:04 PM   #1622
Cooler King is offline Cooler King  United Kingdom
Just received my Toroidy transformer. I am a compete newbie here. I've asked a friend, but I'd like to confirm with you guys please. As you can see, secondaries are Red-Red, Brown-Brown.
So does red-red go to one bridge rectifier and brown-brown to the other rectifier?
Also, as this is 230v, UK voltage. Do I have one CL-60 on the live-neutral connector and x1 cap across the two white transformer inputs? I know this should be obvious, but want to double/triple check.
Thanks all for your much appreciated help!
Old 4th March 2021, 04:37 PM   #1623
avitkauskas is offline avitkauskas  Lithuania
Yes, you are right about red-red and brown-brown.
Capacitor goes between the live and neutral. C60 goes on the live wire from the switch to the transformer. Perhaps pictures will help.
File Type: jpg 6118344E-6E4A-4D87-9222-2B92E4C9806F.jpg (947.2 KB, 160 views)
File Type: jpg CA48C316-8610-4216-8E03-8A260C2DF030.jpg (997.5 KB, 153 views)
Builds: ACA, M2X, F5, Aleph J, Noir, Akitika PR-102 & GT-102, Elekit TU-8200R, Overnight Sensations
Old 4th March 2021, 04:51 PM   #1624
That's brilliant, thank you very much! I always thought the safety capacitor went on the transformer side.. And the CL-60 on the switch side. But I'll follow your pictures, thanks again!
Old 4th March 2021, 05:14 PM   #1625
To be sure, notice that CL-60 does not go across the live and neutral (as capacitor does), it goes on the live wire.
Old 4th March 2021, 05:37 PM   #1626
Got it! Thank you so much..
Old 4th March 2021, 08:30 PM   #1627
myleftear's Avatar
The safety capacitor should be placed right after the iec, the masters said (not too long ago). I put it right at the IEC‘s connector-blades...
dobedobedo...
Old 4th March 2021, 08:47 PM   #1628
Ok, thank you.. I'll see if I can fit it there, although I've got this far at the moment..
Does it look ok? First time I've attempted to build a amp after 35 years in the hobby!
Old 4th March 2021, 09:38 PM   #1629
andynor is offline andynor  Norway
Looks fantastic!! Great job.
Burnt & playin’ BA-3 / WLS18 in progress
Old 4th March 2021, 09:43 PM   #1630
Thank you, appreciate that buddy
diyAudio Power Supply Circuit Board v3 illustrated build guideHide this!Advertise here!
Thread Tools
An illustrated guide to building an F5 6L6 Pass Labs 1809 Today 06:37 PM
Aleph J illustrated build guide 6L6 Pass Labs 6289 Today 03:06 PM
V3 Universal Power Supply Circuit Board Jason The diyAudio Store 478 11th April 2021 02:53 AM
diyAudio F5 Build Guide Jason The diyAudio Store 135 7th September 2020 12:30 AM
An illustrated guide for Aleph 60 builders PKI Pass Labs 58 12th October 2013 07:13 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
