diyAudio Power Supply Circuit Board v3 illustrated build guide
Old 23rd May 2020, 02:10 AM   #1291
Extreme_Boky is offline Extreme_Boky
Originally Posted by Mark Johnson View Post
This Vishay diode is in the exact same package, but its datasheet has a larger amount of information about thermal resistance. Maybe it will be a useful surrogate?
Thanks for the suggestion.
Old 28th May 2020, 05:00 PM   #1292
derekr is offline derekr  Barbados
Originally Posted by Ben Mah View Post
Another option is to use Molex bullet plug connectors on the wires.
Snap Plugs and Receptacles - Molex
Colour code them so no mistakes in hookup. The advantage of connection in the wire over connection on the board is that there is not excess force exerted on the board during connection or disconnection.
Ha! Those connectors conjure up suppressed nightmares of Ďgood oldí Lucas electrics on vintage cars. I have a knee jerk aversion to them for this reason but Iím sure they will work in this context. Good point re the stress relief on the board.
If only there was an alternative that didnít remind of fiddling blind behind an Elan dashboard with those things
Old 29th May 2020, 12:31 AM   #1293
Ben Mah is offline Ben Mah  Canada
I've experienced the work of the Prince of Darkness, Joseph Lucas' company. I had a TR6 once.
Old Yesterday, 05:46 PM   #1294
Tom V is offline Tom V  United States
Default Confused about wiring wall power to transformer
This picture is from the F4 Build thread. I am confused about the wiring of the AC power to the transformer. I am US 110V power.
I would expect:
AC Line >> CL-60 >> 2 Red Transformer inputs
AC Neutral >> CL-60 >> 2 Black Transformer Inputs
Small Capacitor linking AC Line and AC Neutral
1) This picture appears to show one red wire linked to the mains thru an inrush CL-60 and the other linked directly (in the same hole). Similar for the two black wires. Why arenít the two reds and two blacks wired identically?
2) Inside the transformer are there two separate red/black >> blue/green paths, or are they linked?
3) On the other end of the transformer am I correct in thinking that one blue and green pair goes to Left Rectifier Bridge, and the other pair goes to Right Rectifier Bridge?
Thanks,
-Tom-
Burning Amp Festival: Releasing the Magic Smoke since 2007!
Old Yesterday, 05:53 PM   #1295
Mark Johnson is offline Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
TomV I have different expectations than you.
If the two 120V primaries are named "Alice" and "Bob",
I expect to see a CL-60 in series with Bob_Red
I expect to see a CL-60 in series with Alice_Black
image attached.
Old Yesterday, 06:08 PM   #1296
If your transformer is an Antek, here is the info from Antek showing windings:
File Type: jpg AS_4218__09756.1389717596.1280.1280.jpg (164.8 KB, 34 views)
Old Yesterday, 06:18 PM   #1297
Thanks Mark,
That appears to be exactly what the picture shows. I will wire it that way even though I don't understand it.
Is it a good idea to fire up the power supply before the F6 boards are attached to verify +&- 25 volts and a lack of magic smoke?
Thanks Ben,
Indeed it is an Antek 4218.
-Tom-
Old Yesterday, 06:44 PM   #1298
Tom,
Definitely test the power supply before connecting the amplifier board. Also, test each channel separately. Do not connect both channels initially.
Also use a dim bulb tester for initial powerups to guard against damage in case of accidental shorts, etc.
Ben
diyAudio Power Supply Circuit Board v3 illustrated build guideHide this!Advertise here!
Aleph J illustrated build guide 6L6 Pass Labs 5137 Today 12:49 PM
V3 Universal Power Supply Circuit Board Jason The diyAudio Store 412 31st May 2020 07:45 PM
An illustrated guide to building an F5 6L6 Pass Labs 1347 7th May 2020 11:14 PM
diyAudio F5 Build Guide Jason The diyAudio Store 112 19th April 2020 04:39 PM
An illustrated guide for Aleph 60 builders PKI Pass Labs 58 12th October 2013 07:13 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
