diyAudio Power Supply Circuit Board v3 illustrated build guide
Old 17th May 2020, 08:34 PM   #1281
soldersmoker is offline soldersmoker  United States
What's a good ballpark figure for the diode's heatsink's C/W (thermal resistance)? I'm using FEP30DP and the PSU will be powering an F4.
Old 17th May 2020, 09:15 PM   #1282
Mark Johnson is online now Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
This Vishay diode is in the exact same package, but its datasheet has a larger amount of information about thermal resistance. Maybe it will be a useful surrogate?
Old 17th May 2020, 09:24 PM   #1283
6L6 is offline 6L6  United States
6L6's Avatar
Ive run the FEP30DP with no heatsinks, in similar circumstances. They heat up, but not too bad. (YMMV)
Look at their forward voltage drop vs. temperature curve, it’s interesting.
Old 17th May 2020, 10:12 PM   #1284
Thanks Jim, I really appreciate your help. I see the current drops off a table after the temperature hits 100C according to the forward current derating curve. I didn't notice anything about the forward voltage drop though. But there's a lot I miss . . .
And thank you, Mark, but it looks like I can use what I have after all.
Old 22nd May 2020, 12:53 AM   #1285
lonepine510 is offline lonepine510
Forgive me if this has been asked- are there recommendations for connectors so that one can swap out different amp boards at a later time, using the same PSU? I just ordered the PCB and this is my first time building a PSU. Thanks!
Old 22nd May 2020, 10:13 AM   #1286
ItsAllInMyHead is offline ItsAllInMyHead  United States
Many people use FastOn type connections.
Something like this. Check the datasheet for dimensions etc to make sure, but I think this matches what I used.
1287 Keystone Electronics | Connectors, Interconnects | DigiKey
If you want a friend, feed any animal - Perry Farrell
Old 22nd May 2020, 05:46 PM   #1287
rollingtube is offline rollingtube  Germany
this just to report success in building a v3 universal PSU - MUR3020W rectifiers, 8x22000F capacity, 24V rails. Easy build, works like charm. I was just surprised how hot (still touchable) the heat sinks get...working duty on an 0.95A-biased stereo F6 with ventilated cover plate.
The only "problematic" point I had was that the space between the rectifier heat sinks are quite tight for the transformer snubbers - so some of that went under the PCB. Otherwise, no issues. Thanks everyone who worked on the design of this!
Old 22nd May 2020, 08:06 PM   #1288
thompsontechs is offline thompsontechs  United States
Freedom or Death
thompsontechs's Avatar
Might want to insulate those bare legs on the LED, it'd be pretty easy to bend them into a short. Just sayn.
Who's your Daddy? Pappa of course.
Old 22nd May 2020, 10:30 PM   #1289
Ben Mah is offline Ben Mah  Canada
Another option is to use Molex bullet plug connectors on the wires.
Snap Plugs and Receptacles - Molex
Colour code them so no mistakes in hookup. The advantage of connection in the wire over connection on the board is that there is not excess force exerted on the board during connection or disconnection.
Old 22nd May 2020, 11:51 PM   #1290
oooooooh - those are nifty! Thanks, Ben. I've added a few of those to my next cart to try out.
diyAudio Power Supply Circuit Board v3 illustrated build guideHide this!Advertise here!
diyAudio F5 Build Guide Jason The diyAudio Store 120 3rd July 2020 10:32 AM
Aleph J illustrated build guide 6L6 Pass Labs 5254 3rd July 2020 02:47 AM
V3 Universal Power Supply Circuit Board Jason The diyAudio Store 417 28th June 2020 10:07 PM
An illustrated guide to building an F5 6L6 Pass Labs 1359 20th June 2020 08:39 PM
An illustrated guide for Aleph 60 builders PKI Pass Labs 58 12th October 2013 07:13 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
