diyAudio Power Supply Circuit Board v3 illustrated build guide
diyAudio Power Supply Circuit Board v3 illustrated build guide Please consider donating to help us continue to serve you.
Old 30th August 2014, 06:29 PM   #111
R.I.P.
Definitely wired wrong.
The mains current enters the tester plug top goes THROUGH the bulb filament to the tester socket. If any switch is open or the bulb removed, the resistance MUST measure open circuit.
The Neutral from Tester Plug to Tester Socket should ALWAYS measure <<0r1
regards Andrew T.
Old 30th August 2014, 07:09 PM   #112
richluvsound is offline richluvsound  United Kingdom
richluvsound's Avatar
As soon as I connect the transformer I get problems ….. Wired the neutral to one primary and live to the other primary ?
Old 30th August 2014, 07:11 PM   #113
R.I.P.
The Neutral through the bulb tester should measure 0r0 or very close.
The Live through the bulb tester should measure the cold resistance of the bulb.
Check these.
regards Andrew T.
Old 30th August 2014, 07:15 PM   #114
Neutral = 47r1 , Live = 0r
thats reversed ….. ?
Old 30th August 2014, 07:18 PM   #115
R.I.P.
Wrong !
BTW,
47r1 for a cold 100W filament seems about right.
Should be around 580r HOT !
regards Andrew T.
Old 30th August 2014, 07:18 PM   #116
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Light bulb tester thread:
Light Bulb Tester
Kevin
Old 30th August 2014, 07:18 PM   #117
6L6 is offline 6L6  United States
6L6's Avatar
Rich -
You mentioned that you have the bulb-tester on the secondaries - just to clarify, the bulb-tester should be wired in the place of a mains lead from your wall to the amp's IEC (or whatever you have for mains inlet.)
The first place to check is the wiring of the transformer secondaries to the bridges... an error there will immediately blow fuses. Specifically if you have a secondary wired with the winding phase turned 'inside-out'.
I'm flying the next 2 days, but can skype on Monday.
Old 30th August 2014, 07:29 PM   #118
R.I.P.
Remove all the white wires.
Wire Brn from Plug Top to Bulb Holder.
Wire Wht from Bulb holder to LIVE of socket.
Wire Blu from Plug Top to NEUTRAL of socket.
Only the switch in the socket and the bulb filament is in the LIVE half of the bulb tester.
There should be nothing in the Neutral from Plug top to socket.
Remeasure the resistances.
Report back.
regards Andrew T.
Old 30th August 2014, 07:44 PM   #119
Thanks 6L6 ….. I'll be around .
Andrew ,
I have wired the plug and bulb socket as suggested….. I think I need to get a new bulb socket ( this one has a bayonet ,with a threaded bulb adapter ) ….. I'll do that in the morning .
Richard
Old 31st August 2014, 11:45 AM   #120
….. New bulb socket . Still get a circuit with the bulb removed and the switch off …. musty be the plug socket ?
diyAudio Power Supply Circuit Board v3 illustrated build guideHide this!Advertise here!
Aleph J illustrated build guide 6L6 Pass Labs 4563 Today 02:15 PM
diyAudio F5 Build Guide Jason The diyAudio Store 109 25th January 2020 04:14 PM
An illustrated guide to building an F5 6L6 Pass Labs 1221 17th December 2019 03:22 PM
V3 Universal Power Supply Circuit Board Jason The diyAudio Store 388 12th February 2019 10:33 AM
An illustrated guide for Aleph 60 builders PKI Pass Labs 58 12th October 2013 08:13 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
