Simple, no-math transformer snubber using Quasimodo test-jig
Old 19th June 2019, 11:15 PM   #1631
MMAdams is offline MMAdams  United States
Mark, are you a source for the quasimodo boards?
Old 19th June 2019, 11:47 PM   #1632
BYRTT is offline BYRTT  Denmark
BYRTT's Avatar
Originally Posted by MMAdams View Post
I have looked for dsolodov, but not sure how to make the search.
dsolodov kits are to find in posts 1360/1320/1169/1105/777/697/662 and can say its a nice quality kit where each component is labeled into small plastic bags ...
About search for a members posts per thread one can use "Search this thread" and write in some non natural for example 10 time number 5 and hit "Go" which bringes up a new advanced search dialog where one can delete the 10 times number 5 and and use the other field called "Search By User Name".
Old 26th June 2019, 02:44 AM   #1633
OK, thanks BRYTT.
Old 29th June 2019, 11:07 AM   #1634
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
@ Mark Johnson
It's possible to design or change something in Quasimodo to test valve output transformers?
TIA
Felipe
Old 1st July 2019, 08:19 PM   #1635
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Valve output transformers are not mentioned in the Quasimodo design note. That's because I don't know anything about them. However you could check post #323 in this thread to see what other members have thought about doing.
Old 1st July 2019, 09:29 PM   #1636
Thank you Mark.
Old 6th July 2019, 02:43 AM   #1637
ticknpop is offline ticknpop  Canada
Why would you snub a tube output transformer?
The purpose of the snubber is to control the ringing of a power supply transformer feeding a diode bridge, not an impedance converting audio transformer.
Old 6th July 2019, 09:16 AM   #1638
I don't know how the tube output transformer rings, but if you can take an oscilloscope and you will see how it rings.
Simple, no-math transformer snubber using Quasimodo test-jigHide this!Advertise here!
Balanced input test jig for speaker testing tvrgeek Equipment & Tools 6 3rd March 2013 07:56 PM
Simple test for transformer frequency response? bst Tubes / Valves 1 26th January 2010 09:26 PM
db, gain, and loudness. Simple math Pbassred Multi-Way 16 8th November 2005 03:13 PM
Please confirm my transformer math. leadbelly Tubes / Valves 7 12th March 2005 12:52 AM
CD player laser test jig Fantastic Digital Source 1 25th March 2003 04:45 PM
Copyright ©1999-2019 diyAudio
