Simple, no-math transformer snubber using Quasimodo test-jig
Old 21st April 2019, 03:44 AM   #1541
dewdrop is offline dewdrop  Singapore
On the same token, my mum always tells me to be mindful that being kind or being curt is a fine line depending on how we present it.
Ed
Old 21st April 2019, 01:14 PM   #1542
Johnny Canuck is offline Johnny Canuck  Canada
@Dewdrop,
My lack of sophistication in electronics leads me to use X2/Y2 rated safety capacitors in snubbers where I can, since to me they appear to be "across the line", although generally at low voltage where I use them. I think (?) member Jeff Young gently suggested this previously as well (I unabashedly stand on the shoulders of those wiser/smarter than me.)
Is an X2 rating inappropriate or too conservative? Perhaps, but in the case of an over-voltage/over-current event, I have some assurance that they will fail predictably and not start a fire because of their construction.
A disadvantage is that because of their construction, it's hard to find case sizes smaller than pcm 7.5 or 10 for the capacitance values suggested by Quasimodo. And they may be a bit more expensive than non-safety caps.
I have been using Kemet R46 and Rifa PHE840 without event.
Old 21st April 2019, 02:05 PM   #1543
6L6 is offline 6L6  United States
6L6's Avatar
Originally Posted by dewdrop View Post
Thanks Jim, you are always very kind to all the brands. ;-)
Because in this application there’s absolutely no difference at all. Operational and on-spec is all that matters.
Old 21st April 2019, 02:58 PM   #1544
Originally Posted by Johnny Canuck View Post
@Dewdrop,
Thanks Johnny!
Ed
Old 21st April 2019, 03:07 PM   #1545
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Occasionally I've thought about replacing Cx in a transformer secondary snubber, with a Metal Oxide Varistor. MOVs are overvoltage protection devices, similar to big gigantic bidirectional zener diodes. Because of their large size, big MOVs have lots of capacitance between their terminals. Some datasheets say it's tens of nanofarads. Bingo, right in Cx territory.
Unfortunately, the capacitance of a MOV is nonlinear. It varies with voltage. This makes Quasimodo-style testing a bit more involved, since now you must apply the correct bias voltage to "Cx" while performing the bell-ringing experiments. It's probably possible but undoubtedly messy.
It might be true that using a surge protector outlet strip, between the audio equipment and the AC mains, is easier.
Old 21st April 2019, 04:26 PM   #1546
phase is offline phase  United States
I assembled a decent L C filter within a metal cased power strip. It works well, and need to make another one, but the inductor cores had been a common item at Radio Shack, so I need to hunt down a very similar one to use.
Old 21st April 2019, 06:04 PM   #1547
The other end of the spectrum is a G.D.T. (gas discharge tube) whose capacitance is tiny, sub-10pF, because it's just a pair of electrodes in a gas envelope. One of these could connect in parallel with snubbing Cx, and you would simply use Quasimodo in its standard configuration.
Old Yesterday, 09:29 AM   #1548
kaaang1252oo is offline kaaang1252oo
nice,
Simple, no-math transformer snubber using Quasimodo test-jigHide this!Advertise here!
Balanced input test jig for speaker testing tvrgeek Equipment & Tools 6 3rd March 2013 07:56 PM
Simple test for transformer frequency response? bst Tubes / Valves 1 26th January 2010 09:26 PM
db, gain, and loudness. Simple math Pbassred Multi-Way 16 8th November 2005 03:13 PM
Please confirm my transformer math. leadbelly Tubes / Valves 7 12th March 2005 12:52 AM
CD player laser test jig Fantastic Digital Source 1 25th March 2003 04:45 PM
Copyright ©1999-2019 diyAudio
