Simple, no-math transformer snubber using Quasimodo test-jig
Old 7th November 2018, 06:57 AM   #1381
Blitz is offline Blitz  Germany
Mark,
Yes I believe your drawing is right, please look at the second page of this very nice article Fig.56. There you see what I mean:
https://www.die-wuestens.de/iz/RECT.pdf
Thanks a lot !
Old 8th November 2018, 03:28 AM   #1382
SyncTronX is offline SyncTronX  United States
SyncTronX's Avatar
Default Interesting
Blitz,
That's interesting. Here is a look at some of the specs for 80 series rectifiers. Check out the voltage drops between the tubes.
Now I know why they were putting mercury in them to keep the voltage drop at 15 Volts versus 60V or 91V for non mercury rectifiers.
Some other tube specs say you can mount the mercury vapor tubes in different ways; e.g., my B&K700 tube tester has it mounted horizontally to keep the case thickness smaller. It is also lined with asbestos cloth to keep it flame retardant.
Blitz pg 75, right column, 1st para. describes Fig 60 as having three rectifiers tubes and delivers three current pulses per cycle.
I wonder how that stacks up against one of them there
high-fa-LOOT-en ZTX/MUR/HEXFRED diode thing-ies?
Cit: General Electric. (date unknown). Tubes, Essential Characteristics: Receiving tubes, Television Picture tubes, Special-purpose tubes. General Electric, Electronic Components Division, Schenectady 5, New York, U.S.A.
-- Sync
Old 9th November 2018, 12:32 AM   #1383
Rick PA Stadel is offline Rick PA Stadel  United States
The 3-pulses-per-cycle configurations are driven by 3-phase AC.
Rick
Old 9th November 2018, 05:30 AM   #1384
SyncTronX's Avatar
Thanks Rick,
and 120 degree phase difference too.
Question: With UF and Freds etc., wasn't too clear, with each switch on/off being a small step of the 60 Hz AC wave. there would be very very small increments that increase or decrease according to the phase angle as opposed to a rectifier having one long pulse per 360 pulse?
Wondering how many for the Freds. Now that I think about it, it's in their data sheet and is the 1/time, i.e., frequency.
-- Sync
Old 9th November 2018, 05:55 AM   #1385
EUVL is offline EUVL  Europe
Someone asked by PM what is the aluminium extrusion housing I used in my build in post #952. Thank you for your interest. It is a simple, cheap aluminium extrusion housing I bought years ago from the Electronic Flea Market in Shumsuipo, Hong Kong. Measures 100x 75 x 35mm.
You can get much better quality ones from Fischer, e.g. the FR 80 42 100 ME. FR 80 42, Design cases, Cases f.case, Fischer Elektronik Available from Reichelt, Buerklin, ...., etc.
Blank cases, so you have to do your own cutout.
Cheers, Patrick
xen-audio.com
Old 9th November 2018, 06:05 AM   #1386
This one also should fit :
https://www.hammfg.com/files/parts/pdf/1550Z107.pdf
Patrick
xen-audio.com
Old 9th November 2018, 02:11 PM   #1387
Mark Johnson is online now Mark Johnson  United States
Mark Johnson's Avatar
I just leave my Quasimodos (and Cheapomodos) as bare PCBs with no enclosure at all. Partly that's because my lab bench is an electrical isolator: cheap Ikea melamine laminate. Partly that's because I run my tests using low voltage DC power supplies, so low that they won't cause electric shocks if I touch exposed components.
I tape the Quasimodo/Cheapomodo PCB to the lab bench using blue painter's tape. Then I connect wires to the supply (crocodile clips) and to the transformer (Euroblox screw down terminals), and I tape those wires to the bench too, making the apparatus even more steady. Then I connect my scope probe(s) and ground clip(s) and start measuring.
An advantage of leaving *modo as a bare board with no enclosure, is that it doesn't take up much storage room. I've got four of them in a little plastic food storage tub with a lid, plus an assortment of different values of snubber capacitor and trimmer potentiometer in a tiny ziplock bag.
Another advantage of no enclosure is: it's easy to probe internal nodes if you want to. It's also easy to remove the trimmer, measure its resistance, and reinstall the trimmer onto the board. Without needlessly long wires connecting off-PCB to a front panel mounted pot, wires which add unwanted inductance to the snubbing impedance.
It's a tool to be used, two or three times a year, and then tossed back in the closet to make room on the lab bench for other tools. It's not a sculpture to be revered and admired. Notice the words "test jig" in the title of this thread and on the title page of the Quasimodo design note. They convey the degree of fancy presentation that Quasimodo deserves: none.
If my lab bench were made of conductive metal instead of insulating plastic, I suppose I would probably bolt one of my Quasiomodos onto a block of wood, a block which is thick enough and heavy enough to prevent tipping over: the "small and heavy" design. Another design which prevents tipping over is the "large and light" block of wood, whose dimensions are much bigger than the Quasimodo PCB, say 30 cm by 15 cm. Now the wood block can be only 5mm thick. Center the little 10 by 5 cm PCB on this block and it will never tip over. But it is awfully big and annoying to store.
Old 9th November 2018, 07:31 PM   #1388
SyncTronX's Avatar
Thank you Mark, Patrick, Rick, and others for explaining. It is these thoughts that you share that help me keep my thinking on track and focused.
So now I've got all the hard to gather parts to build a proper Quasimodo v4 especially the link and parts from Arrow, which other distributers didn't have. Chalk up one for our side.
Going back through the X-modo threads I've picked up and a few common themes.
Mark doesn't like fooling around with Oxen-Scheisse processes and proceedures.
If it can be done quickly and cheaply (it doesn't mean using inferior parts) saving time he goes for it. He also doesn't baby sit you and expects one to do their share of the fun.
I'm in the process of reconciling the layout on the cheapo-modo vectorboard with the V4 through hole board and their schematics on a vectorboard for me. I just realized (I'm slow) that I should be looking at the Gerber files to see the trace layouts. Now I'm wondering if it would have been better to get a different vectorboard (not the one with the horizontal traces across the length but either the one with three holes per trace of the a pad per hole.
I was going to add to this but I've just had a "mature moment" (I forgot what it was.)
-- Sync
Old 11th November 2018, 01:14 PM   #1389
I got my Quasimodo up and running...great machine. While I am still in the learning phase, may I ask how do you measure / optimize the snubbers for each individual leg of a Centre Tapped transformer ?
I have read the manual and when I connect one secondary end to CT as described there, I get a nice clean curve. When I leave it open, So I measure only one leg and leave the second leg unconnected, I get a bit of a different curve with some riplles in it like if you would have when other secondaries on the same transformer are left open. We are here talking about a larger EI transformer with 450-0-450V...so how would you actually measure each leg correctly without the other open leg influencing the measurement ?
Simple, no-math transformer snubber using Quasimodo test-jigHide this!Advertise here!
Balanced input test jig for speaker testing tvrgeek Equipment & Tools 6 3rd March 2013 08:56 PM
Simple test for transformer frequency response? bst Tubes / Valves 1 26th January 2010 10:26 PM
db, gain, and loudness. Simple math Pbassred Multi-Way 16 8th November 2005 04:13 PM
Please confirm my transformer math. leadbelly Tubes / Valves 7 12th March 2005 01:52 AM
CD player laser test jig Fantastic Digital Source 1 25th March 2003 05:45 PM
