A single LED on an dual DC supply?
Old 21st December 2012, 10:48 PM   #41
teleman is offline teleman  Norway
Thanks guys for your invaluable inputs! I've been doing some thinking & my thoughts go like this.
Electrons in a conductive material travel freely,yet the movement of these molecules depend or restricted by the inherent friction of this conductive material. This friction,then can be called the "resistance" -R- of that particular conductive material. Now, if we then apply a force to this material, then it would move even faster & more force we inrodduce, faster will these electrons move, yet the resistance of the material remains constant right?
Lets say that this force is V,voltage. So, when we apply more voltage, then the electrons too should move faster. However, the resistance will not allow all the voltage to pass through & consequently a certain amount of voltage or is dropped across this resistor. So my question is, where does that dropped voltage go & what happens to it? As HEAT perhaps?
Another simple analogy will be the lowly light bulb! What makes a 60w bulb brighter than a 40 watt one? Doesn't a 60w consume more power (W)= current x voltage than a 40w? Why? Then wouldn't this have the same effect as using a more current demanding brighter LED than a less brighter low current one?
Old 22nd December 2012, 08:10 AM   #42
sofaspud is offline sofaspud  United States
sofaspud's Avatar
...yet the resistance of the material remains constant right?
At a constant temperature, yes, the resistance may remain constant. The resistance is caused by charge carriers colliding with other fixed particles in the conductor. I'm not 100% certain so don't quote me.
...where does that dropped voltage go...?
I mentioned it before in post #39... current isn't across a component and voltage isn't through a component. You have those concepts backwards. Voltage across points A and B allows current through from A to B.
The electrons don't move faster; the voltage causes more electrons to move. Once you understand the above, that voltage is across two points, you may better understand that it doesn't really go anywhere.
Perhaps the simplest example uses a capacitor. Placing a voltage across the two plates causes an excess of electrons on one plate (the negative side) and a deficit of electrons on the other plate (the positive side). If a short is then placed across the capacitor terminals, the excess electrons on the negative side will move to fill in where electrons are lacking on the positive side. The voltage hasn't gone anywhere, it has only more or less balanced itself among all the available atoms.
An electron must acquire energy to jump from one atom, and releases energy when it falls into a hole in another atom. At least some of that energy is released as heat.
With both operating at the same voltage, it is an increase in current that results in the increase in watts. With more current the lamp filament can glow hotter and/or brighter. LEDs are different than incandescent because in this case, when an electron falls into a hole with an LED, some energy is released not as heat but as a photon of light. More current means more electrons falling into holes.
This is all in the physics category moreso than benchtop electronics. Look for basic semiconductor tutorials online or in a textbook. It will explain better than I and will show why certain elements like silicon and germanium are best suited for semiconductor electronics, and why other elements such as boron or arsenic are best suited for achieving desirable semiconductor characteristics.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 17th October 2019, 01:14 PM   #43
Mixi is offline Mixi  Europe
The OT asked for a single multicolour LED to be placed in a dual DC supply. Now my question is a bit simpler I hope. I'd like to add one single "power on" led to a dual supply like this one: P05-Mini
Where in this schematic can I put one single power on LED? Between V+ and GND I assume (with a resistor). Before or after the regulators?
Old 17th October 2019, 01:42 PM   #44
FauxFrench is offline FauxFrench  France
You can put the LED (with a resistor) from"+" to GND, from GND to "-" or from "+" to "-". Before or after the regulator(s).
A LED you don't want to shine too bright takes 2-3mA, no more. The LED current is unimportant for the power consumption.
The current controlling resistor may take a bit more than expected power loss because almost all the voltage will be across it. About 3mW per volt.
Old 17th October 2019, 01:55 PM   #45
thanks fauxfrench! so it seems that it really doesn't matter where i put it? but will it cause an "imbalance" between the rails if i "take" voltage / current only from one rail?
Old 17th October 2019, 02:39 PM   #46
In theory yes, but why do you think that the rails are loaded exactly equal (within 3mA) with the normal load? Only with two same value precision resistors on the two outputs will the loading be the same.
Any amplifier you use on the rails will not draw (exactly) the same current from "+" and "-".
Such symmetrical regulated power supplies perform as two substantially independent power supplies. A positive and a negative. Say we use 1.5A LM317/337 regulators - you can draw 1A from one rail and no current from the other for long without a problem. The voltages remain constant and numerically the same if designed for equal values.
Emotionally, I understand your feeling of asymmetry/imbalance and if you make a virtual unregulated midpoint of a higher voltage, asymmetrical loading will influence the midpoint voltage.
Old 17th October 2019, 02:57 PM   #47
Makes sense, thank you very much! I'll put a single LED with a resistor between "+" and gnd and try not to think about it any further :-)
Old 17th October 2019, 04:46 PM   #48
stocktrader200 is offline stocktrader200  Canada
connect LED to positive rail connect npn transistor emitter to negative rail with 220k resistor from base to ground (10k base to emitter). connect LED cathode 4.7k resistor to collector.
LED won't light unless there is power on both rails.
Old 17th October 2019, 11:58 PM   #49
Mark Tillotson is offline Mark Tillotson
Whoops, mistake there, all charge carriers react to the applied electric field and move faster for a stronger field on average. Actually the random thermal motion is orders of magnitude larger, but only the concerted net drift in the direction of the field is visible externally as a current(*), and this "drift velocity" is an average.
(*) actually the thermal motion is visible as Johnson noise, but this is a tiny.
A single LED on an dual DC supply?Hide this!Advertise here!
Using dual supply OPamp ( NE5532 ) with single Supply? KidCe Analog Line Level 4 1st December 2018 10:51 PM
use single side of dual supply b0red2tears Power Supplies 8 12th February 2017 01:51 PM
Single supply vs. dual supply and noise, I can't find a proper solution Plecto Power Supplies 16 2nd August 2013 06:14 PM
10 W Class AB amp: Adapting Single Supply to Dual Supply jonatmudd Solid State 13 18th March 2011 08:02 PM
Lm1875, Single Or Dual Supply alcuemar Chip Amps 5 24th May 2006 04:02 PM
Copyright ©1999-2019 diyAudio
