Tony's latest traffo DIY build
Thread Tools
Old 19th March 2021, 09:43 AM   #1041
TonyTecson is offline TonyTecson  Philippines
diyAudio Moderator Emeritus
TonyTecson's Avatar
Originally Posted by Kay Pirinha View Post
Wow, those are monster C cores! What power capability would your estimate at 50Hz grids?
Best regards!
this was from an isolation traffo rated for 1000watts/50 hz...300 watts at 30 hz is a reasonable expectation imho...
Old 23rd March 2021, 01:36 PM   #1042
gorgon53 is offline gorgon53  Finland
360VA if you can squeeze in the same amount of copper and can liv with the distortion at maxed out induction.
I use 0.5T at 50Hz for lowest distortion (distortion increases at higher induction, starting from 0.4T, inductance reaches a max somewhere between 0.8 and 1.2T), this would give at most 80W output but it all depends on what you need or want want. In the old days 0.4-0.6T at 40Hz (allowing maxed out inductance at 20Hz) was considered best for minimum distortion with 3%Si Goss (McIntosh squeezed out a bit more, 75W with only 4kg of iron, but that is because the high amount of fb allowed for a bit higher transformer distortion)
Old 24th March 2021, 12:40 AM   #1043
TonyTecson's Avatar
those were 6kg a piece ....thanks gorgon53
Old 12th June 2021, 08:45 AM   #1044
mariogert is offline mariogert  Netherlands
Originally Posted by TonyTecson View Post
this is a power traffo using a 2inch center leg stacked to 3 1/4 inch DEECO silicon steel (noss) irons..
specs are as follows:
primary: 220 volts 60hz.
secondary1: 250volts at 2amps.
secondary2: 100volts at 0.5amps
secondary3: 12.6volts at 10 amps
secondary5&6: 6.3 volts at 3 amps
completed, there are 3 chokes sitting on top, 1/2inch, 5/8 inch, aqnd 3/4 inch.
testing prior to dipping in polyuretahne varnish
line voltage:
magnetizing current:
unloaded core apparent power:
actual unloaded power in watts:
power factor:
Dear Tony,
I have a tube preamp thet wants 120V and 12V power supply fom 230V AC EU mains power.
Would it be possible for you to make me a transformer with dual 120V and 12V outputs like the one here? Please quote in PM.
Greetings,
Mario G Rouwenhorst
Netherlands
  Reply to this post
Tony's latest traffo DIY buildHide this!Advertise here!
Thread Tools
tony's 6LU8 push-pull power amp build TonyTecson Tubes / Valves 31 7th April 2018 02:56 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 2 4th October 2017 01:03 AM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 07:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 12:34 AM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 11:50 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
