Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#1031 |
If there's really a rectifier, I'd short it's diodes by applying wire bridges appropriately.
Best regards!
"I spent a lot of money on booze, birds and fast cars. The rest I just squandered." (George Best) |
#1032 | |
Just want to know if it is going to work ? ) Last edited by daniboun; 25th October 2020 at 12:23 PM. |
#1033 |
diyAudio Moderator Emeritus
the A3 required +-25 split rails....
two 25volt smps stacked in series, that is what i will use...
https://www.facebook.com/tony.tecson |
#1034 | |
So thought that 28 VDC SMPS 500W (dual rail) should be OK. 20V AC x 1.4 = 28 V DC ZEROZONE assembleld Ver 2.0 passe A3 classe A Mono amplificateur carte 30W Amp bricolage (pas de dissipateur thermique) | AliExpress Last edited by daniboun; 25th October 2020 at 01:09 PM. |
#1035 |
your amp shows too many filter caps, so then i doubt that smps is what you need..
looks like toroid traffo is all you need..... ![]()
https://www.facebook.com/tony.tecson Last edited by TonyTecson; 26th October 2020 at 02:10 AM. |
#1036 | |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
tony's 6LU8 push-pull power amp build | TonyTecson | Tubes / Valves | 31 | 7th April 2018 03:56 AM |
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 | LinuksGuru | Tubes / Valves | 2 | 4th October 2017 02:03 AM |
Trinium, my latest build | Mark.Clappers | Multi-Way | 18 | 17th July 2012 08:07 PM |
My latest CHR-70 build | tresch | Full Range | 8 | 6th December 2011 01:34 AM |
My latest build SS 23W | smithy666 | Subwoofers | 6 | 14th April 2009 12:50 PM |
New To Site? | Need Help? |
